Tambilin
Slow/Poor Internet connection
I was hoping to get some help. Our internet connection has suddenly become really slow over the last few days. We are on the VIVID 150 plan however speeds have dropped down to only 1Mbps on both ethernet and wireless connections. We still have an internet connection however it is now too slow to watch videos without poor resolution & constant buffering. After reading some other posts I have tried resetting the router several times and checked all of the physical wired connections which has now increased download speeds this morning to about 15Mbps, however this has not helped restore the connection to the full speeds we had a week ago. Below is the router status logs:
Downstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 250750000 234750000 242750000 258750000 266750000 274750000 282750000 290750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 43 41 42 44 61 62 63 64
Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV) 5.34 5.47 5.30 5.60 5.52 5.22 5.26 4.97
RxMER (dB) 38.61 38.26 38.26 38.26 39.40 39.40 39.40 38.61
Pre RS Errors 317 407 311 940 967 931 290 923
Post RS Errors 300 306 309 939 965 930 290 922
Upstream   US-1 US-2 US-3 US-4
Channel Type 2.0 N/A N/A 2.0
Channel ID 2 N/A N/A 1
Frequency (Hz) 39400000 N/A N/A 46200000
Ranging Status Success Other Other Success
Modulation 16QAM N/A N/A 16QAM
Symbol Rate (Sym/sec) 5120000 N/A N/A 5120000
Mini-Slot Size 4 N/A N/A 4
Power Level (dBmV) 44.71 N/A N/A 44.71
T1 Timeouts 0 0 0 0
T2 Timeouts 0 0 0 0
T3 Timeouts 0 0 0 0
T4 Timeouts 0 0 0 0
First Time Last Time Priority Error Number Description
29/01/2017 10:20:49 GMT 29/01/2017 10:20:49 GMT Warning (5) 66050310 Auth Success - Web login successful.
29/01/2017 09:42:22 GMT 29/01/2017 09:42:22 GMT Error (4) 68010302 DHCP WAN IP - #########
29/01/2017 09:41:29 GMT 29/01/2017 09:41:29 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Notice (6) 84000510 Downstream Locked Successfully
29/01/2017 09:25:12 GMT 29/01/2017 09:25:12 GMT Warning (5) 84020200 Lost MDD Timeout
29/01/2017 09:22:20 GMT 29/01/2017 09:22:20 GMT Warning (5) 84020200 Lost MDD Timeout
29/01/2017 09:09:20 GMT 29/01/2017 09:09:20 GMT Warning (5) 84020200 Lost MDD Timeout
29/01/2017 09:07:36 GMT 29/01/2017 09:07:36 GMT Warning (5) 84020200 Lost MDD Timeout
29/01/2017 09:07:08 GMT 29/01/2017 09:07:08 GMT Warning (5) 84020200 Lost MDD Timeout
29/01/2017 09:06:52 GMT 29/01/2017 09:06:52 GMT Warning (5) 84020200 Lost MDD Timeout
29/01/2017 09:03:11 GMT 29/01/2017 09:03:11 GMT Warning (5) 84020200 Lost MDD Timeout
29/01/2017 08:38:14 GMT 29/01/2017 08:38:14 GMT Warning (5) 84020200 Lost MDD Timeout
29/01/2017 08:37:06 GMT 29/01/2017 08:37:06 GMT Warning (5) 84020200 Lost MDD Timeout
29/01/2017 08:36:46 GMT 29/01/2017 08:36:46 GMT Warning (5) 84020200 Lost MDD Timeout
29/01/2017 08:35:30 GMT 29/01/2017 08:35:30 GMT Warning (5) 84020200 Lost MDD Timeout
29/01/2017 08:35:14 GMT 29/01/2017 08:35:14 GMT Warning (5) 84020200 Lost MDD Timeout
29/01/2017 08:34:10 GMT 29/01/2017 08:34:10 GMT Warning (5) 84020200 Lost MDD Timeout
29/01/2017 08:33:50 GMT 29/01/2017 08:33:50 GMT Warning (5) 84020200 Lost MDD Timeout
29/01/2017 08:20:24 GMT 29/01/2017 08:20:24 GMT Warning (5) 84020200 Lost MDD Timeout
29/01/2017 08:07:15 GMT 29/01/2017 08:07:15 GMT Warning (5) 84020200 Lost MDD Timeout
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
  • 8.29K
  • 355
  • 583
Re: Slow/Poor Internet connection
Hi Tambilin,
Welcome to the Community!
Really sorry to hear you're experiencing speed issues.
I've run a diagnostic on your equipment and everything is looking healthy at the moment. Your signal levels are as they should be and there are no issues with the network in your area.
Are you connected wired or wirelessly?
I'd like you to try running a speed test with the hub in Modem Mode to see what kind of results you get.
Speak soon Smiley Very Happy
Josh
