botne539
Slow Internet Speed on Wired and Wireless
Okay so when we first got Virgin media internet in the speeds were perfect. Now it's difficult to reach 3mb/s download speed at night with it usually peaking at 20mb/s in the afternoon. This is with the 100mb/s package. I've tried restarting the router which does nothing and sometimes stops the internet from working all together for around 15 minutes. One strange thing is that upload speed always seems to be relatively fine at around 6mb/s. It is just really frustrating especially considering i've been putting up with this issue for months now hoping that it would fix itself.
  • 9.36K
  • 800
  • 1.96K
Re: Slow Internet Speed on Wired and Wireless
Posting some basic diagnostic info may help.
Navigate to the hub's GUI using http://192.168.100.1
Don't log in, click the Router Status button in the top right of the screen.
Copy \ Paste the Downstream, Upstream, and Network Logs.
Don't worry about the formatting, but do obscure personal information like your WAN IP address.
botne539
I don't know if you'll be able to understand this but cheers for the quick reply.
Downstream
1299000000-20.928.7256 qam212323000000-22.727.2256 qam243315000000-22.827256 qam234307000000-21.428.4256 qam225291000000-20.929.1256 qam206283000000-20.529.3256 qam197275000000-20.229.9256 qam188267000000-19.930256 qam179259000000-19.830.2256 qam1610251000000-19.530.4256 qam1511243000000-19.530.4256 qam1412235000000-19.730.4256 qam13
Upstream
1839400000ATDMA46.864 qam640000051201932600000ATDMA46.816 qam64000005120
Network log
2017-03-19 15:10:51.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-03-19 15:10:57.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-03-19 15:12:11.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-03-19 15:14:23.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-03-19 15:16:25.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-03-19 15:16:43.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-03-19 15:18:33.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-03-19 15:25:41.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-03-19 15:25:45.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-03-19 15:27:01.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-03-19 15:27:51.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-03-19 15:28:27.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-03-19 15:29:51.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-03-19 15:31:29.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-03-19 15:31:45.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-03-19 15:33:19.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-03-19 15:34:25.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-03-19 15:34:59.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-03-19 15:35:45.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2017-03-19 15:37:27.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 9.36K
  • 800
  • 1.96K
Can understand it fine thanks.
Your downstream power levels are way too low and the downstream SNR is out of spec.
If you have a barrel shaped attenuator screwed to the coax at the back of the hub you could try removing it but i doubt if it will completely resolve the problem.
With your downstream power levels so low it would be hard to say if the evening slowdown will be down to contention or the instability of your connection. VM will be able to check when they pick up the thread.
You will need to contact VM for resolution, either by waiting here about a week until a VM Forum Team Member picks up the thread, or give them a call on 150 from a VM line or 0345 454 1111 for a quicker response.
botne539
Okay thanks for the help. We have phoned virgin media customer support and an engineer is being sent out this Tuesday. Hopefully he can fix the issue Smiley Happy
botne539
I looked at what you said about a cylinder plugged in at the back of my router and removed something that said equaliser on it. Anyway my speeds have increased from 3mb/s to 65mb/s. 95mb/s on my wireless. I don't know if this fix will work for ever but for now it is. So yeah.
