  • 8
lazarou
Message 1 of 11
Slow Download Speed
Recently installed a Super hub 3 to replace a faulty Super hub 2 and I am receiving around 25 Mbps, even late at night.  I currently pay for the 200 Mbps services.
Downstream
Channel Frequency(Hz) Power
(dBmV) SNR
(dB) Modulation Channel ID
12990000005.340.3256 qam57
23230000005.440.3256 qam60
33150000005.340.3256 qam59
43070000005.340.9256 qam58
52910000005.440.3256 qam56
62830000005.440.3256 qam55
72750000005.440.3256 qam54
82670000005.640.3256 qam53
92590000005.140.9256 qam52
102510000005.340.3256 qam51
112430000005.540.9256 qam50
122350000005.440.9256 qam49
Upstream
Channel ID Frequency(Hz) Mode Power
946200000ATDMA47.364 qam64000005120
1039400000ATDMA47.364 qam64000005120
Before the SH2 went faulty I regularly got download speeds of 200 Mbps, any ideas what could be causing such low speeds with the SH3?
  • 9.38K
  • 312
  • 1.01K
Message 2 of 11
Re: Slow Download Speed
Hello lazarou
I am sorry you are having some problems with speed, the area traffic does pick up a bit in the evening but not too bad. The hub and line look good. Are you measuring from a wireless connection or wired. If not doing it already please try wired with www.speedtest.net leaving the default server at different times of the day and let us know how that goes.
Nicola
Virgin Media Forum Team
  • 8
lazarou
Message 3 of 11
Hi Nicola,
There is an engineer calling today, have spoken to 2nd line support who confirmed I was getting poor download speeds, even in modem mode connected directly to my Pc.
  • 10.82K
  • 308
  • 632
Message 4 of 11
Hi there lazarou,
Thanks for getting back to us.
I'm glad to hear you arranged an engineer appointment to check the connection.
Has there been an improvement with the speeds or are you still having the same issue?
Speak soon
Sam
  • 8
lazarou
Message 5 of 11
Hi Sam,
unfortunately my issue is unresolved. The technician determined that the fault was not with my set up but with my area and was unsure when it would be fixed. I am considering reducing my broadband package to 50Mb if I will be unable to receive the 200Mb service for the foreseeable future.  I seem to be getting from 25Mb to 45Mb on average.
  • 10.82K
  • 308
  • 632
Message 6 of 11
Morning lazarou,
Thanks for the reply.
I've checked this over and the engineer has left notes in regards to a high peak time traffic fault in your area. The reference number is F005054947, and work is to be completed with an estimated date of April.
If there is anything else you would like me to check by all means let me know.
Sam
  • 8
lazarou
Message 7 of 11
Thanks Sam, I will hold off until June and hopefully the issue will be resolved.
  • 62
  • 20
wonko
Dialled in
Message 8 of 11
And so the cycle of disillusionment begins...
  • 8
lazarou
Message 9 of 11
You're probably right, and if it isn't resolved by start of June I will be changing my account.
  • 8
lazarou
Message 10 of 11
Update:
I have been checking my connecting speed regularly and for the last few days I have been getting 200+. Hopefully this means whatever issue was causing problems in my area has now been resolved (fingers crossed).
