carruthersmj
Message 1 of 5
Slow Broadband
I'm paying for 50Mb, but most evenings seem to get about 4Mb.  I'm in region 21 - NW London, and this has been happening since November..
Does anyone else have this issue, and any ideas how to improve it?  I've reported the issue a couple of times with no results.
  • 2.96K
  • 378
  • 939
Message 2 of 5
Re: Slow Broadband
Slow speeds at peak times (typically 4pm-11pm weekdays and weekends) but full speed at off peak times is normally a symptom of high utilisation/contention in your area.  Are your off peak speeds OK?
Somebody from the VM forum team should be along in a few days (up to a week) to check your connection and can confirm if there is a known issue with your segment of the network. If that is the case they should provide a fault reference and pass your details onto another team who should inform you about your credit options for the lack of service via a PM. They should also be able to provide a review date for the fault. Note that it is a review date not an expected fix date and some customers affected by this kind of issue have been waiting over a year for a fix.
______________________
Scott
  • 7.29K
  • 307
  • 520
Message 3 of 5
Re: Slow Broadband
Hi carruthersmj,
Thanks for posting!
Really sorry to hear you're having trouble with your connection.
I've located your account and I can see an issue with the network in your area affecting speeds at peak times - Ref.(F004271731). Our technicians are working to get this sorted as soon as possible and have set a review date of 8th February.
I'm really sorry for any inconvenience this may cause.
Josh
carruthersmj
Message 4 of 5
Re: Slow Broadband
Thanks Josh,
Unfortunately this has been going on for about 2 months, and I have been told on a few occasions that its a technical problem and is being looked into...
Is there anything more definite that you can tell me?  Can I be upgraded to get a more reasonable speed in the evenings?
Many thanks
Malcolm
  • 7.29K
  • 307
  • 520
Message 5 of 5
Re: Slow Broadband
Hi Malcolm,
Our team is working to upgrade the network in your area to support increased demand. It's unlikely that an upgrade will do much to help with this kind of issue.
I'm really sorry, I know this is frustrating!
All the best
Josh
