John_1981
Slow Broadband speed
I've been having issues with slow broadband for the last couple of months logged a couple of calls with helpdesk but unfortunately not a lot has changed. I am running download tests from a PC which is directly wired to my superhub 2ac and am getting on average between 10-20MB max speeds. I am currently on the VIVID 200 Optical Fibre plan. I am unable to log a call with the help desk as my phone has been broken since 01/12/16.
Date ascending                  Download          Upload       Latency Server        Distance
12/13/2016 9:04 PM GMT  11.37 Mb/s         11.46 Mb/s 26 ms Eastbourne   ~ 50 mi
12/6/2016 8:13 PM GMT    28.06 Mb/s           12.21 Mb/s 52 ms Studley           ~ 100 mi
12/6/2016 8:07 PM GMT    16.70 Mb/s           12.28 Mb/s 17 ms Brentford        ~ 50 mi
12/6/2016 11:59 AM GMT   217.80 Mb/s       12.38 Mb/s 15 ms Cowes        < 50 mi
11/11/2016 8:44 PM GMT   25.16 Mb/s         12.22 Mb/s 31 ms Cowes          < 50 mi
10/4/2016 8:52 PM GMT     9.60 Mb/s             12.25 Mb/s 15 ms Woking             ~ 50 mi
10/2/2016 6:20 PM GMT    29.89 Mb/s           12.26 Mb/s 20 ms Brentford        ~ 50 mi
10/2/2016 6:08 PM GMT   16.36 Mb/s           11.18 Mb/s 35 ms Bournemouth ~ 50 mi
I have rebooted the router on many occasions to no avail. Had a look at the network logs and constantly see the following
82000200 No Ranging Response received - T3 time-out
68000411 TOD error 4861 msec
67070100 DBC-ACK not received
Network status shows
Downstream Channels
Lock Status Channel ID Frequency Modulation Rx Power RxMER Pre RS Errors Post RS Errors
Locked 39 250750000 Hz 256 QAM -0.8 dBmV 37.6 dB 23768 4200
Locked 37 234750000 Hz 256 QAM -1.4 dBmV 36.8 dB 28913 5446
Locked 38 242750000 Hz 256 QAM -1.1 dBmV 36.8 dB 24552 5119
Locked 40 258750000 Hz 256 QAM -0.7 dBmV 37.1 dB 16179 4682
Locked 41 266750000 Hz 256 QAM -1.0 dBmV 37.9 dB 12289 3946
Locked 42 274750000 Hz 256 QAM -1.5 dBmV 37.6 dB 12032 4075
Locked 43 282750000 Hz 256 QAM -1.6 dBmV 37.6 dB 10407 3136
Locked 44 290750000 Hz 256 QAM -1.5 dBmV 37.6 dB 9279 2477
Upstream Channels
Lock Status Channel ID Frequency Modulation Tx Power Mode Channel Bandwidth Symbol Rate
Locked 60 25800000 Hz ATDMA 50.3 dBmV 64QAM 6400000 Hz 5120 Ksym/sec
NotLocked 0 0 Hz 0 dBmV 0 Ksym/sec
Locked 59 32600000 Hz ATDMA 50.8 dBmV 64QAM 6400000 Hz 5120 Ksym/sec
  • 10.82K
  • 308
  • 631
Re: Slow Broadband speed
Hi John_1981,
Thanks for posting and a warm welcome to the community.
Sorry to see that you are having issues with the broadband speeds.
When I checked your connection, there is a high peak time traffic fault in your area which is causing slow speeds. This will coincide with the speed tests you completed. The reference number is F004031061 and has a review date of 11th January 2017.
I will pass this across to one of my colleagues who will be in touch with more information.
Sam
