ronniea
Signal Strength
I am using the virgin 3 hub and 100mbs speed. i live in a 4 bedroom house. The hub is located more or less in a central position. However i keep losing signal in three bedrooms? cant understand it. The new hub should have a stronger signal range and easily cover a 4 bed house?
  • 5.66K
  • 291
  • 1.25K
Re: Signal Strength
If the virgin router (quite basic compared to the market) doesn't cut it, then you have a couple options.
1) running Ethernet cables through.
2) same as above but have access points at the end, instead of just having the one Ethernet cable for a device at the end. Give best wireless on a per room basis.
3) powerline adapters
4) get a good 3rd party AC router, upgrade network card to AC if not already. Put the superhub in modem mode and plug it in.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
