Tluvolin
Reaching only half of speed
Why is my broadband running at half speed?
I'm paying for 100Mb/s and reach only half of this speed.
Did Virgin lowered my speed or is that problem with my router?
  • 22.22K
  • 845
  • 3.23K
Re: Reaching only half of speed
how are you testing the speed what device are you testing on? Are you connected wired or wireless when testing?
  • 16.46K
  • 1.37K
  • 3.36K
hiya @Tluvolin could be issue with network utilisation, to check a few basics how are you connected wired/wireless?, if using wireless could you test the speed using wired, also would be worth checking on the hub is doing, if you could goto http://192.168.0.1 clicking router status [no need to login] and copy/paste the downstream, upstream, operational config.
Tluvolin
Thanks for quick response.
I am connected via wifi and my Virgin router is running in modem mode with Linksys router running wifi here is my speed tested on Ookla website [URL=http://beta.speedtest.net/result/5969303644][IMG]http://beta.speedtest.net/result/5969303644.png[/IM...]
Tluvolin
  • 16.46K
  • 1.37K
  • 3.36K
with wireless there is a lot of things that can cause interference lowering the speed.. to get the full 100mbps would require a wired conneciton
