  • 410
  • 7
  • 75
echelom
Fibre optic
Message 1 of 7
Probably a stupid question, but does Rain cause problems with Broadband Services?
Hi all,
I cannot see that I am alone on this issue, but it is weird to say the least. I know VM uses fibre optic cables, hubs then cables to our premises, so in theory the weather conditions to a certain extent should not affect our 200Mb broadband speed.
But, what we find is this, bear in mind our property has had cabled "pulled" twice by network engineers and technical engineers, yet this issue still exists.
If we have heavy rain, or bad winds - you can guarantee our 200Mb connection becomes really unstable, more so noticed on "consoles" (XBOX ONE & PS4). It causes signing in problems, getting kicked out of games, etc.
With our iPads on 5Ghz or 2.4Ghz they start buffering on forever. PC's are not too bad unless we are on NetFlix or YouTube. If I do a few checks on Speed Test, I try a few servers but it's always the same - the downstream drops to around 110Mb per sec! This causes a drop for a split second in the connection, hence our only option is a "hard reset".
Does anyone else suffer from this problem?
Regards,
  • 20.74K
  • 554
  • 3.21K
Sephiroth
Message 2 of 7
Re: Probably a stupid question, but does Rain cause problems with Broadband Services?
If water gets into your Omnibox or drop point box, electrolytic effects can occur leading to signal degradation. But you'd have that most of the time once stuff has got regularly wet.
If the temperature falls, then metal in the coax contracts and thus the signal power rises. If it goes above 10 dBmv downstream, you could get problems.
  • 440
  • 16
  • 46
ILuvNips
Fibre optic
Message 3 of 7
Virgin have had past problems with their green boxes where water would get in but I thought these issues had long been fixed. Only reason I know about this is that an engineer commented that at that time they had been applying mastic to lids of the boxes as temporary fixes.
________________________________________________________________
In HA7. Billing Area 21.
Utilisation Fault
F003502423: Review Dates -> 07/10/2015 -> 02/12/2015 -> 20/01/2016 Smiley Sad -> Closed Smiley Happy
Utilisation Fault F004873444: Review Dates -> 29/03/2017 Smiley Sad -> Closed Smiley Happy
  • 23
happyrobot
Message 4 of 7
I think rain is causing my connection problems too. When we moved in the wires were exposed (rented property).
The box covering the cables is very loosely covering the cables. I've actually seen many boxes like this in our area with cables exposed.
Who's responsibility is this? Virgin's to fix or me (my landlord)?
  • 410
  • 7
  • 75
echelom
Fibre optic
Message 5 of 7
Hi there,
That would be Virginmedia's responsibilty not yours. Give them a ring on 150
You reminded me, I still haven't got ours fixed yet!
Regards.
Echelom
  • 23
happyrobot
Message 6 of 7
Thanks! Two years is a long time Smiley Wink
  • 8
carter_dj
Message 7 of 7
No.  It is not a stupid question.  I too am affected by high winds.  I had the same problem with BT, EE, Sky and now Virgin.
Right now I'm using my phone tethering in order to post this as out internet has been in and out all day.
It's not rain, leakage to boxes etc as some other posit, there is no rain, just wind.   Now being an Ex BT employee, I know the atmosphere can affect latency on broadband, but like you, my assumption of fibre to box and copper to the router, being only 10yds away from the green box on the street, plus this being a newly installed area - it all begs the question - whats going on????
What I'm experiencing is the broadband signal fading in and out all day long, with the internal wifi working, but the root out failing (the exclamation mark on the wifi signal indicator).
I've re-booted and had a signal for like 5 mins and then it fades in and out again......
I'm going to research some more, but definitely yes this is a "thing".
