  • 7
oaksi82
Message 1 of 12
Poor connection speed (wired). 3 - 4 Mbps.
Hi all,
I had virgin broadband installed a fortnight ago. Initial speed hard wired was 0.5 meg, which support assured me would settle down and reach closer to 40 meg.  However, I get between 2-3 Mbps, whilst paying for "up to" 50.
support just suggest router resets, and moving the router, but after 17 days of trying I'm slightly fed up of their fob-off attitude.
all tips and advice would be highly appreciated
Helpful Answers
  • 2.62K
  • 209
  • 799
Dave_cq
Trouble shooter
Message 2 of 12
Re: Poor connection speed (wired). 3 - 4 Mbps.
In circumstances like this it is always useful to start by checking the upload and download statistics in the Virgin Hub.
Open a browser window and input the URL 192.168.0.1 and this should open up the hub's management screen.   Do NOT sign in but simply click on Router Status and post here the Upstream and Downstream stats.
********* SuperHub 2ac - Asus rt-ac68u Router - Vivid 100Mbps **********
Electron
All Replies
  • 2.62K
  • 209
  • 799
Dave_cq
Trouble shooter
Message 2 of 12
Electron
  • 7
oaksi82
Message 3 of 12
I'll do that now Dave, thanks for the tip!
  • 7
oaksi82
Message 4 of 12
Unfortunately, it is insisting I sign in, the only password I can see on the router is the wifi password which it doesn't take...image.png
  • 2.62K
  • 209
  • 799
Dave_cq
Trouble shooter
Message 5 of 12
Cant see the image you've posted at the moment ... apparently newcomers have their images vetted by the moderators before they will appear.
Which hub do you have?
Electron
  • 7
oaksi82
Message 6 of 12
had to sign in, located settings password on the bottom of the router. Hard stuff this for a tech noob!
  • 7
oaksi82
Message 7 of 12
Apparently it's called hub 3.0
  • 2.62K
  • 209
  • 799
Dave_cq
Trouble shooter
Message 8 of 12
Ah ok, I'm afraid I'm not familiar with the newest Hub 3 but I'm sure there must be a screen that shows your Upstream & Downstream figures.
Electron
  • 7
oaksi82
Message 9 of 12
Here are the upstream and downstream stats as requested. image.pngimage.pngimage.png
  • 10.82K
  • 308
  • 631
Message 10 of 12
Evening oaksi82,
Sorry to read that you are having issues with your broadband speeds.
From checking your connection, there is a high peak time traffic fault in your area which is causing slow speeds. Our networks team are investigating the problem and are improving bandwidth and performance to help with this issue. The reference number is F003477649 and with a review date of 28th December.
As you getting these speeds at all times of the day or just during peak hours?
Speak soon
Sam
