jay2
Settling in
Please help with slow speeds..
Im on 100mb and the past few weeks have been woeful.
My last speedtest from about 5 minutes ago was..... Ping 15ms,  DL 5.59mbps and UL 5.93mbps.
This is one of the better results, its averaging around 1mbps.
Im in the Dudley area, is there a fault somewhere?
Helpful Answers
  • 9.36K
  • 800
  • 1.96K
Re: Please help with slow speeds..
Stats look fine, just a single T4 in the logs, but apart from that it looks good.
What are the wired speeds during the day? It would be useful to know to check if your area is overutilised.
It might be worth starting a Broadband Quality Monitor here. You will need to enable Respond to ICMP Eco Requests first in the hub's GUI advanced section.
jay2
Settling in
Im at work so its hard to test in the daytime.
If the stats look fine, what else could be causing the slow speeds?
All Replies
  • 9.36K
  • 800
  • 1.96K
Are you testing with a device connected directly to the hub by ethernet cable, or wirelessly?
If wireless, I would test the speed with a wired device during the day and again during evening peak period.
jay2
Settling in
Hi Griffin, its a wired connection.
Will add the superhub status below, hope it can be made out...
Downstream
DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 291000000 Hz 251000000 Hz 259000000 Hz 267000000 Hz 275000000 Hz 283000000 Hz 299000000 Hz 307000000 Hz
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 16 11 12 13 14 15 17 18
Modulation QAM256 QAM256 QAM256 QAM256 QAM256 QAM256 QAM256 QAM256
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17
Power Level (dBmV) 0.3 dBmV -2.6 dBmV -2.5 dBmV -2.0 dBmV -1.7 dBmV -0.1 dBmV -0.6 dBmV -1.5 dBmV
RxMER (dB) 39.0 dB 37.5 dB 37.8 dB 38.2 dB 38.6 dB 38.9 dB 37.9 dB 37.9 dB
Upstream
US-1 US-2 US-3 US-4
Channel Type 2.0 2.0 N/A N/A
Channel ID 3 2 N/A N/A
Frequency (Hz) 32600000 Hz 39400000 Hz N/A N/A
Ranging Status Success Success N/A N/A
Modulation QAM16 QAM16 N/A N/A
Symbol Rate (Sym/sec) 5120000 5120000 N/A N/A
Mini-Slot Size 128 128 N/A N/A
Power Level (dBmV) 46.5 dBmV 45.3 dBmV N/A N/A
T1 Timeouts 0 0 N/A N/A
T2 Timeouts 0 0 N/A N/A
T3 Timeouts 0 0 N/A N/A
T4 Timeouts 0 0 N/A N/A
First Time Last Time Priority Error Number Description
09/00/2017 20:24:53 09/00/2017 20:24:53 Error (4) 68010400 DHCP REBIND WARNING - Field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/00/2017 21:39:10 09/00/2017 21:39:10 Critical (3) 2436694078 TOD established
03/00/2017 17:25:40 03/00/2017 17:25:40 Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 9.36K
  • 800
  • 1.96K
jay2
Settling in
Bandit1294
Hi im in halesowen been slow speeds since november due to  overutilised had the same problem last year they gave me a date in december for fix now moved it to april im getting a credit on my account every month till it's fixed this  might be effecting you give them a ring .
