  • 171
  • 5
nigel1969
Message 1 of 22
Ping Issues WV13
For the past 10 months there has been a utilization issue in my area which i was told was causing my ping issues and fluctuating internet speeds. Recently i received a message on here saying that the fault in my area had been fixed but my connection is still the same.
I have had 4 techs out and had my router swapped about 4 times over the last 10 months and i am 100% certain the issue does not lie at my house/end.
My broadband package is vivid 200 but the speed constantly fluctuates and always get a different reading every time i do speed tests and i currently have a superhub 3.
I currently can't do a ping test as it says it is blocked via firewall even though it shouldn't be
I mainly use my connection for gaming so as you can imagine this has become an annoying experience for me.
Tracing route to bbc.co.uk [212.58.244.23]
over a maximum of 30 hops:
1 5 ms 3 ms 3 ms 192.168.0.1
2 16 ms 15 ms 18 ms 10.34.240.1
3 11 ms 15 ms 21 ms wolv-core-2b-xe-133-0.network.virginmedia.net [6
2.253.73.229]
4 * * * Request timed out.
5 18 ms 21 ms 21 ms brhm-bb-1c-ae0-0.network.virginmedia.net [62.254
.42.110]
6 23 ms 23 ms 18 ms tcl5-ic-2-ae0-0.network.virginmedia.net [212.250
.15.210]
7 23 ms 33 ms 18 ms 212.58.239.249
8 * * * Request timed out.
9 * * * Request timed out.
10 18 ms 21 ms 25 ms ae0.er01.telhc.bbc.co.uk [132.185.254.109]
11 17 ms 18 ms 28 ms 132.185.255.148
12 30 ms 29 ms 31 ms 212.58.244.23
Trace complete.
  • 8.76K
  • 566
  • 2.42K
Message 2 of 22
Re: Ping Issues WV13
Nothing wrong on your traceroute but your BQM is showing latency going haywire everytime the connection is in use. If its overutilisation, it should do that during peak hours but revert to a normal trace off peak. I suspect there may be something else amiss.
What are the power levels like from your router status screen?
  • 171
  • 5
nigel1969
Message 3 of 22
This has been going on since December last year so 11 months i have been suffering this Smiley Sad fair enough they knock a few quid of your bill but id rather have my connection working.
  • 8.76K
  • 566
  • 2.42K
Message 4 of 22
Power levels are fine. Having a closer look at your BQM, your latency is spiking higher OFF peak than on, most of the time.
Have you anything running on the network that would saturate upstream? P2P ? streaming TO twitch (not from) or similair? Large backups to the cloud?
  • 171
  • 5
nigel1969
Message 5 of 22
  • 8.76K
  • 566
  • 2.42K
Message 6 of 22
In an ideal world on a VM connection you would see steady green, steadyish blue and some yellow spiking.
Your second graph DOES look like overutilisation, unlike the first.
Ill pass it to staff to get some metrics run their end.
  • 171
  • 5
nigel1969
Message 7 of 22
  • 171
  • 5
nigel1969
Message 8 of 22
Phoned them up yesterday they said they couldn't understand why i had received a message on here saying the fault was fixed as it is still on going and will not be fixed until the 23rd of November at 10:30 am.
so i guess that explains why my graph was still looking weird so i guess i just have to wait till then and take it from there.
  • 171
  • 5
nigel1969
Message 9 of 22
Could someone look into this for me please my latency is constantly going up and down.
  • 8.94K
  • 386
  • 629
Message 10 of 22
Hi nigel1969,
Thanks for posting!
I've checked out the account and the network fault has been closed down as completed. I've also run a diagnostic on your equipment and all the levels are showing great at the moment. Are you still experiencing latency issues?
Look forward to hearing from you! Smiley Very Happy
Josh
