  • 21
paul59
Message 1 of 13
Paying for 200 receiving 100 or less.
Hello I realise many others have this issue but as I pay for a 200mbit service I'd like to receive one.
Been testing using iphone 5 s and Speedtest app
best numbers are these.
Helpful Answers
  • 14.44K
  • 641
  • 1.46K
Moderator
Moderator
Message 2 of 13
Re: Paying for 200 receiving 100 or less.
Hi Paul59,
Thanks for posting your speed test. That is actually a fairly typical speed over wireless and may be limited by the phones internal wireless receiver. Could you try a speed test from a wired PC and see if you're getting the same?
  • 12
Sishake
Message 9 of 13
Your lucky with the speed you get
We have 5.6mbps download if lucky and download of 7 no matter how many times we complain it's still poor. Should have stayed with sky
All Replies
  • 14.44K
  • 641
  • 1.46K
Moderator
Moderator
Message 2 of 13
Hi Paul59,
  • 21
paul59
Message 3 of 13
http://www.speedtest.net/my-result/5964087974
This is my result with a Samsung RF711 Laptop using a Alcatel Data Cable.
Take your point about wireless.
More tests reveal our MacAir on wireless does indeed give 200+ Mbps
How do we get our laptop to operate at full speed?
  • 9.34K
  • 797
  • 1.96K
Message 4 of 13
I am a bit confused about the Alcatel Data Cable. as these tend to be USB data cables, How areyou connecting it to the hub?
The Laptop has a Realtek Gigabit ethernet adapter which should be fine for 200Mbps connected directly to the hub by Cat 5E or better Ethernet cable.
  • 21
paul59
Message 5 of 13
The cable has a Ethernet connector at either end and it just plugs into the router in the Ethernet socket. I'm guessing it's not the right cable?
  • 21
paul59
Message 6 of 13
  • 9.34K
  • 797
  • 1.96K
Message 7 of 13
Does it have Cat or Category 5 printed on it?
Cat 5 cables are rated for 100Mbps with Cat 5e and acove rated for 1000Mbps.
It might be worth popping in to your local PC shop and buying a Cat 5e or Cat 6 cable for a few quid. Never hurts to have a spare one knocking about
  • 21
paul59
Message 8 of 13
I'll get the right cable then.
  • 12
Sishake
Message 9 of 13
  • 21
paul59
Message 10 of 13
Good luck with Sky/BT
Single figures seems to be the norm
