  • 7
anglerud
Message 1 of 11
Packet loss, up to 60% for large periods
I've got large periods of terrible packet loss. Since yesterday I've been measuring it:
Packet lossPacket loss
For hours at a time, the internet connection is nearly unusable. Restarting the router often (but not always) makes the packet loss go away for a short while. (For example, the dip between 14:25 and 15:57 there is likely my housemate rebooting the router).
I need any help I can get to reduce this problem - even browsing the web is nearly impossible when the packet loss is at its worst.
  • 7
anglerud
Message 2 of 11
Re: Packet loss, up to 60% for large periods
The packet loss continues - here's the measurement for the past week(ish):
The internet connection is periodically not usable. Bouncing the router brings back the connection for a while again.
  • 8.62K
  • 552
  • 2.38K
Message 3 of 11
 Set up a BQM
HERE
Run it for say 24 hrs, and post the result.
Dont forget youll need to make sure your super hub is configured to reply to ICMP echo requests...
  • 7
anglerud
Message 4 of 11
Today's been amazingly much better:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/1abf0a02b0813957dc0fc4b59e8cd3b8e52601d4-09-08-2017
Compare the external and intenal monitoring - and they agree well:
I'm going to keep the monitor going for while.
  • 8.62K
  • 552
  • 2.38K
Message 5 of 11
Youve still got packet loss. So keep it running, come back and tell us if it kicks off again...
  • 7
anglerud
Message 6 of 11
Good call on keeping the monitoring going. Unfortunately, it looks like the packet loss is picking back up again:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/fe4b77e9751ec086c469d19b1bc481b82df478ff-12-08-2017
  • 10.64K
  • 313
  • 656
Message 7 of 11
Hey anglerud,
Sorry to see the problems you're having with your connection. Everything looks good from our end so I'm hoping this has settled down for you now.
Do you still need help with this?
Take care.
Heather_J
  • 7
anglerud
Message 8 of 11
Thank you for your reply.
A virgin media technician came around and re-crimped the coax connector, and replaced the router. She said it'd take a while to settle in, so I've given it a bit of time to see if things would improve. Unfortunately, I still get dropouts, here is yesterday:
[MOD EDIT: Inappropriate Image removed (Contains IP address), please review the Forum Guidelines]
https://www.thinkbroadband.com/broadband/monitoring/quality/share/e53822f59977d83abfbe7a9756f9ee5130...
  • 7
anglerud
Message 9 of 11
Interestingly, there is also a constant low level packet loss:
$ ping www.yahoo.com
PING atsv2-fp.wg1.b.yahoo.com (46.228.47.115) 56(84) bytes of data.
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=1 ttl=55 time=31.3 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=2 ttl=55 time=27.8 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=3 ttl=55 time=25.9 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=4 ttl=55 time=25.9 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=5 ttl=55 time=24.3 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=6 ttl=55 time=25.7 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=7 ttl=55 time=87.7 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=8 ttl=55 time=27.8 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=9 ttl=55 time=36.0 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=10 ttl=55 time=34.9 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=11 ttl=55 time=27.2 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=12 ttl=55 time=23.0 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=13 ttl=55 time=23.8 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=14 ttl=55 time=24.2 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=15 ttl=55 time=30.6 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=17 ttl=55 time=27.2 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=19 ttl=55 time=27.8 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=20 ttl=55 time=26.8 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=21 ttl=55 time=27.6 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=22 ttl=55 time=25.2 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=23 ttl=55 time=24.6 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=24 ttl=55 time=23.0 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=25 ttl=55 time=22.0 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=26 ttl=55 time=29.0 ms
64 bytes from ir1.fp.vip.ir2.yahoo.com (46.228.47.115): icmp_seq=27 ttl=55 time=22.9 ms
^C
--- atsv2-fp.wg1.b.yahoo.com ping statistics ---
27 packets transmitted, 25 received, 7% packet loss, time 26068ms
rtt min/avg/max/mdev = 22.018/29.339/87.740/12.404 ms
And this can be seen from my intenal monitoring as well:
Packetloss, intenal monitorPacketloss, intenal monitor
An interesting correlation is that when the average latency to the first hop outside the router shot up to ~450ms, packetloss went down to close to 0. Otherwise it hovers between 2 and 5%.
  • 7
anglerud
Message 10 of 11
and today was unfortunately much worse:
bank holiday dropoutsbank holiday dropouts
There were fairly long periods today when I couldn't really do much.
