ExilevRandall
Message 1 of 8
Not getting no where near what im paying for
Hi I had my broadband installed on 2nd of this Month However since its been installed i am as of yet to see Speeds im paying for i Have VIVID 200 Optical Fibre When running a speed test all im getting is
http://beta.speedtest.net/result/6514641572
Channel Frequency(Hz) Power SNR (DB) Modulation Channel id
1        298750000 3.4 38.9 256 qam 9
2        322750000 3.5 38.9 256 qam 12
3        314750000 3 38.9 256 qam 11
4 306750000 2.9 38.9 256 qam 10
5 290750000 3 38.9 256 qam 8
6 282750000 3 38.9 256 qam 7
7 274750000 3 38.9 256 qam 6
8 266750000 3 38.6 256 qam 5
9 258750000 2.7 38.9 256 qam 4
10 250750000 3.2 38.6 256 qam 3
11 242750000 3 38.6 256 qam 2
12 234750000 3.4 38.6 256 qam 1
Channel ID Frequency(Hz) Mode Power
2 39400000 ATDMA 31 64 qam 6400000 5120
3 32600000 ATDMA 31 64 qam 6400000 5120
MAC has been **** for Reasons
Date And Time Error Number Event Description
2017-08-05 04:56:50.00 84000500 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=************;CMTS-MAC=************;CM-QOS=1.1;CM-VER=3.0;
2017-08-05 04:56:50.00 84000700 RCS Partial Service;CM-MAC=************;CMTS-MAC=************;CM-QOS=1.1;CM-VER=3.0;
2017-08-05 04:56:55.00 84020200 Lost MDD Timeout;CM-MAC=************;CMTS-MAC=************;CM-QOS=1.1;CM-VER=3.0;
2017-08-05 04:57:36.00 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=************;CMTS-MAC=************;CM-QOS=1.1;CM-VER=3.0;
2017-08-05 05:02:35.00 85010200 TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=************;CM-QOS=1.1;CM-VER=3.0;
2017-08-05 05:02:37.00 67070100 DBC-ACK not received;CM-MAC=************;CMTS-MAC=************;CM-QOS=1.1;CM-VER=3.0;
2017-08-05 05:03:18.00 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=************;CMTS-MAC=************;CM-QOS=1.1;CM-VER=3.0;
2017-08-05 05:11:20.00 85010200 TCS Partial Service;CM-MAC=************;CMTS-MAC=************;CM-QOS=1.1;CM-VER=3.0;
2017-08-05 05:11:22.00 67070100 DBC-ACK not received;CM-MAC=************;CMTS-MAC=************;CM-QOS=1.1;CM-VER=3.0;
2017-08-05 05:12:06.00 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=************;CMTS-MAC=************;CM-QOS=1.1;CM-VER=3.0;
2017-08-05 05:20:11.00 85010200 TCS Partial Service;CM-MAC=************;CMTS-MAC=************;CM-QOS=1.1;CM-VER=3.0;
2017-08-05 05:20:13.00 67070100 DBC-ACK not received;CM-MAC=************;CMTS-MAC=************;CM-QOS=1.1;CM-VER=3.0;
2017-08-05 05:20:56.00 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=************;CMTS-MAC=************;CM-QOS=1.1;CM-VER=3.0;
2017-08-05 05:29:00.00 85010200 TCS Partial Service;CM-MAC=************;CMTS-MAC=************;CM-QOS=1.1;CM-VER=3.0;
2017-08-05 05:29:02.00 67070100 DBC-ACK not received;CM-MAC=************;CMTS-MAC=************;CM-QOS=1.1;CM-VER=3.0;
2017-08-05 05:29:46.00 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=************;CMTS-MAC=************;CM-QOS=1.1;CM-VER=3.0;
2017-08-05 05:38:12.00 85010200 TCS Partial Service;CM-MAC=************;CMTS-MAC=************;CM-QOS=1.1;CM-VER=3.0;
2017-08-05 05:38:14.00 67070100 DBC-ACK not received;CM-MAC=************;CMTS-MAC=************;CM-QOS=1.1;CM-VER=3.0;
2017-08-05 05:38:57.00 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=************;CMTS-MAC=************;CM-QOS=1.1;CM-VER=3.0;
  • 16.48K
  • 1.37K
  • 3.36K
Message 2 of 8
Re: Not getting no where near what im paying for
your upstream power is rather on the low side, would be checking all connections are finger tight..since high chance this will require a tech visit to increase power levels, you can wait for a forum admin to arrange this wait time around a week, or by calling broadband support via 150 / 0345 454 1111..
also with the connection is this via wired/wireless?, if its wireless could you test it via wired..
ExilevRandall
Message 3 of 8
Hi thanks for the Quick Response All Connections are Tight and this is with a Cat 6 Ethernet cable from Router straight to PC
  • 10.82K
  • 308
  • 632
Message 4 of 8
Hi ExilevRandall,
Sorry to read you are experiencing slow broadband speeds.
Looking at your connection, the power levels are now within range and there are no faults reported.
Have you noticed an improvement with the broadband speeds or are you still having the same issue?
Kind regards
Sam
ExilevRandall
Message 5 of 8
Hi i had a engineer out and he had to Replace the Hub since then it has calmed down. thank you
  • 3.14K
  • 36
  • 601
Ignition
Trouble shooter
Message 6 of 8
Good news. You should get an upgrade in your area pretty soon, too.
ExilevRandall
Message 7 of 8
That is Interesting What kind of upgrade since everything is practically new ?
  • 382
  • 23
  • 122
Joe92
Fibre optic
Message 8 of 8
Ignition could you provide an update inside the following thread to the earlier multiple predictions you made at: http://community.virginmedia.com/t5/Speed/Is-it-just-me-or-is-VM-plagued-by-over-sold-services-so-ca... - in particular, replying to Hugh's post 2nd bottom at that link?
If you're sources allow, and for interest, can you provide info of the G11 issue I and many have been suffering for quite some time (F004055880)?
