  • 13
Meup93
Message 1 of 9
Not getting my desired speed
I'm just a bit concerned about my wifi speed they just upgraded me to 200mbps from 100mbps but all my devices are showing 80/90mbps but my mum came around to my house and her phone was showing a speed of 180/190mbps which is what I expect. I have a honor 8 phone my wife has an iPhone 8 and my daughter has a Asus tablet and I have an Asus tablet and all show below half the speed, my mum has a Samsung galaxy S7 and shows the speed I want I'm so confused as it can't be my internet I rang virgin but didn't get the help I needed. I'm a newbie btw
Helpful Answers
  • 13
Meup93
Message 8 of 9
Re: Not getting my desired speed
Thanks its good to hear it's not only me. I'll look into this I never realised there was a wide range of connectivity from phone to phone I'll try update my pc thanks for your help
All Replies
  • 13
Meup93
Message 2 of 9
General Configuration
Network Access Allowed
Maximum Number of CPEs 1
Baseline Privacy Enabled
DOCSIS Mode EuroDOCSIS 3.0
Config File
SFID 162302
Max Traffic Rate 230000000 bps
Max Traffic Burst 42600 bytes
Min Traffic Rate 0 bps
Primary Upstream Service Flow
SFID 162301
Max Traffic Rate 12700000 bps
Max Traffic Burst 16320 bytes
Max Concatenated Burst 16320 bytes
Scheduling Type Best Effort
  • 13
Meup93
Message 3 of 9
Downstream
DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 171000000 179000000 187000000 195000000 203000000 211000000 219000000 227000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 1 2 3 4 5 6 7 8
Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17
Power Level (dBmV) 7.62 7.47 8.29 9.13 9.03 8.19 7.87 7.48
RxMER (dB) 37.64 37.94 37.94 37.94 38.26 38.26 38.26 37.94
Pre RS Errors Reset Counter 6751 4438 435 394 364 342 396 416
Post RS Errors Reset Counter 317 284 284 312 313 290 326 306
  • 22.22K
  • 845
  • 3.23K
Message 4 of 9
it will depend on the quality of the wireless device used. you will need a good 5ghz 802.11ac device to get speeds near or above 200.
If you test the speeds on a PC or laptop using a 1gbps network card you will see the true speed the internet is running at.
Wireless can be effected by many things.
  • 13
Meup93
Message 5 of 9
Hi thanks for the reply, I understand things affect wireless it's just weird my mum can get 180/190 on her galaxy s7 then I get 70/80 and I thought my wife's iPhone 8 would be able to get the higher speeds as hers is a new phone. My pc only has 2.4ghz WiFi so can't really get the true speeds on there by ethernet plus I've no idea about all this really just I might aswel downgrade to 100mbps if it continues. Even my Asus tablet is getting 53mbps it's getting frustrating
  • 13
Meup93
Message 6 of 9
Wi-Fi 802.11 a/b/g/n/ac, dual-band, WiFi Direct, hotspot
That's what my phone supports
  • 51
Northdowns
Message 7 of 9
You are only going to get a 'true speed' via a wired connection. Wifi result vary so widely mobile to mobile - I used to get 60Mbps on Wifi via my Galaxy S6 E+, but get 385Mbps via the Note 8.
Maybe look at upgrading the connectivity in your PC / laptop. Not that expensive these days - just did the laptops wifi for a tenner (USB stick).
*** Just a service user, just like you ***
  • 13
Meup93
Message 8 of 9
  • 13
Meup93
Message 9 of 9
I did this then connected my pc to ethernet and was getting speeds of 160/170mbps and at the minute over my phone wireless I'm getting 23mbps is there anything I can do
