  • 14
garvey2003
Message 1 of 7
New Installation low speed
I just had my broadband installed, had a few issues, like no broadband when the engineer left due to network issue.
Once I had broadband, I had to setup the TV etc. and tested the connection speed all day and the max speed was 135mb nothing else on the network, that's only 2 thirds of the speed I should be getting.
Tested from my wired computer and only get 92mb which will be down to the old Network card not being a gigabyte card, will change that shortly.
Anyway, is this the speed I should expect, as I should be on the 150mb broadband, seems stupid paying for the extra third I can't have. I am a little disappointed so far
Helpful Answers
  • 14
garvey2003
Message 6 of 7
Re: New Installation low speed
Card is fine, just installed a new card with latest drivers etc. tried a few cables. the light is green which should mean gigabit
this is the router status pages
____________________________-
Cable Modem Status
Item Status Comments
Acquired Downstream Channel(Hz) 434750000 Locked
Ranged Upstream Channel(Hz) 39400000 Locked
Provisioning State Online
Channel Frequency(Hz) Power(dBmV) SNR(dB) Modulation Channel ID
1 434750000 6 40.3 256 qam 4
2 562750000 3.2 38.9 256 qam 20
3 554750000 3.4 38.9 256 qam 19
4 546750000 3.5 38.9 256 qam 18
5 538750000 3.5 38.9 256 qam 17
6 530750000 3.9 38.6 256 qam 16
7 522750000 4 38.6 256 qam 15
8 514750000 4.3 38.9 256 qam 14
9 506750000 4.5 38.9 256 qam 13
10 498750000 4.6 38.9 256 qam 12
11 490750000 5 38.9 256 qam 11
12 482750000 5 38.9 256 qam 10
13 474750000 5.1 40.3 256 qam 9
14 466750000 5.4 40.3 256 qam 8
15 458750000 5.5 38.9 256 qam 7
16 450750000 5.5 40.3 256 qam 6
17 442750000 5.6 40.3 256 qam 5
18 426750000 6 40.3 256 qam 3
19 418750000 5.9 40.3 256 qam 2
20 410750000 6 38.9 256 qam 1
Channel ID Frequency(Hz) Mode Power(dBmV) Modulation Channel Bandwidth(Hz) Symbol Rate (ksps)
38 39400000 ATDMA 39.8 64 qam 6400000 5120
40 25800000 ATDMA 39.8 64 qam 6400000 5120
Operational Configuration
General Configuration Value
Network access Enabled
Maximum Number of CPEs 1
Baseline Privacy Enabled
Docsis Mode Docsis30
Config file V0dea97109ea7aa00.cm
SFID 14421
Max Traffic Rate 230000000
Primary Upstream Service Flow
SFID 14420
Max Traffic Rate 12700000
Not sure what I am looking at to be honest
  • 14
garvey2003
Message 7 of 7
Resolved, it would seem I had the wrong Ethernet cable, I had cat5 not cat5e, easy mistake as its been laid for about 12 years haha
All Replies
  • 9.65K
  • 672
  • 1.87K
Message 2 of 7
wireless is anybodies guess - you need to upgrade the lan card in the computer and test again - if thats still low then something is [obviously] wrong - get that done and go from there
Tony
  • 14
garvey2003
Message 3 of 7
card has been checked and is a gigabit card, 93mbps is the max I get not on wifi and wired connection.
Cable Modem Status
Item
Status
Comments
434750000
Locked
39400000
Locked
Provisioning State
Online
  • 11.07K
  • 1.02K
  • 2.26K
Message 4 of 7
Having a gigabit card is not a guarantee of speeds above 100Mb.
Is the card configured for more than 100Mb?
Do you have a good enough cable for high speeds? What colour is the LED on the gigabit card?
  • 11.07K
  • 1.02K
  • 2.26K
Message 5 of 7
Also, are you sure you are on a 150Mb service as it is not a current speed.
What speed does My VirginMedia say you have?
What speed does your Superhub operational configuration say you have?
  • 14
garvey2003
Message 6 of 7
Cable Modem Status
SFID 14421
SFID 14420
  • 14
garvey2003
Message 7 of 7
