Silentsorrow
Need To reset SuperHub2 everyday to get full speed
Good Morning,
Ive had to resort to unplugging my Superhub2 every morning to get anything near the proper speeds im paying for. Did a speedtest before reset and was only getting 2.03mbps this morning (normally get about 35-50mbps), after reset im back upto 190.08mbps (should be around 220mbps).
Ive tried the tech support yesterday and they did something at the other end that gave me proper speeds till about 4pm when it dropped again back to about 98mbps, since im paying for the high end package its becoming quite annoying only getting such poor service when im around and online.
Checked the router status and ive got alot of 84020200 Lost MDD Timeout errors not sure if thats a problem/cause,
Any help would be appreciated.
PC is connected directly into the SuperHub2.
Thanks, Richard.
Silentsorrow
Re: Need To reset SuperHub2 everyday to get full speed
25/03/2017 08:39:36 GMT25/03/2017 08:39:36 GMTWarning (5)84020200Lost MDD Timeout
Lost MDD Timeout
Downstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)242750000202750000210750000218750000226750000234750000250750000258750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID149101112131516
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)2.772.992.752.863.012.842.592.81
RxMER (dB)37.0936.8436.3930.1033.8337.3637.0937.09
Pre RS Errors
2083511718414139427018461310610021345611
Post RS Errors
31531930271009525757339324297
Upstream   US-1 US-2 US-3 US-4
Channel Type2.0N/AN/A2.0
Channel ID26N/AN/A25
Frequency (Hz)39400000N/AN/A46200000
Ranging StatusSuccessOtherOtherSuccess
Modulation16QAMN/AN/A16QAM
Symbol Rate (Sym/sec)5120000N/AN/A5120000
Mini-Slot Size2N/AN/A2
Power Level (dBmV)48.00N/AN/A47.75
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts0000
T4 Timeouts0000
  • 3.88K
  • 121
  • 203
Forum Team (Retired) Adam_L
Hi silentsorrow,
Thanks for posting! I am sorry to hear about your issues with needing to reset your Super Hub everyday to get full speeds, I apologise for any inconvenience.
I have tested the connection from this side and I couldn't detect anything out of the ordinary, no errors or time outs inside the Hubs logs and all of your power levels are within the preferred ranges.
Are you still having these issues? If so, when do they occur all times of day or just specific times?
Is there any noticeable change to the Hubs light sequence when these issues occur?
Please try a wired speed test with the Hub running in modem mode and post the results here for us to see.
Take care,
Adam.
Silentsorrow
Hi Adam,
Ive been resetting every morning as common practice, but since monday i havent had time. Weirdly its not had any drops on speed and the router logs are as follows
27/03/2017 07:30:19 GMT27/03/2017 07:30:19 GMTWarning (5)90000200CSFR Detect - Expired Content Submitted ; LAN Interface
27/03/2017 07:23:15 GMT27/03/2017 07:23:15 GMTError (4)68010302DHCP WAN IP - 86.
27/03/2017 07:22:08 GMT27/03/2017 07:22:08 GMTError (4)68000407TOD established
Time Not EstablishedTime Not EstablishedNotice (6)84000510Downstream Locked Successfully
27/03/2017 07:17:10 GMT27/03/2017 07:17:10 GMTWarning (5)84020200Lost MDD Timeout
27/03/2017 07:16:56 GMT27/03/2017 07:16:56 GMTWarning (5)84020200Lost MDD Timeout
27/03/2017 07:16:48 GMT27/03/2017 07:16:48 GMTWarning (5)84020200Lost MDD Timeout
as you can see ive had no faults since then.
The speed loss normally happens over night sometime so in the morning when i first boot up i have awful speeds until i reset router, it then drops down at 4pm onwards most days except sunday when its most of the day to around 40-90mbps.
In Modem mode the Speed is Ping 13 Download 221.07 Upload 12.04
In Router Mode the speed is Ping 9 Download 220.78 Upload 12.31
Logs after Router/Modem flick
First TimeLast TimePriorityError NumberDescription
29/03/2017 08:35:26 GMT29/03/2017 08:35:26 GMTError (4)68010302DHCP WAN IP - 86.
29/03/2017 08:34:16 GMT29/03/2017 08:34:16 GMTError (4)68000407TOD established
29/03/2017 08:32:51 GMT29/03/2017 08:32:51 GMTWarning (5)66050310Auth Success - Web login successful.
29/03/2017 08:28:48 GMT29/03/2017 08:28:48 GMTError (4)68000407TOD established
29/03/2017 08:20:40 GMT29/03/2017 08:20:40 GMTWarning (5)66050310Auth Success - Web login successful.
29/03/2017 08:20:00 GMT29/03/2017 08:20:00 GMTWarning (5)90000200CSFR Detect - Expired Content Submitted ; LAN Interface
29/03/2017 08:19:58 GMT29/03/2017 08:19:58 GMTError (4)68000407TOD established
29/03/2017 08:19:03 GMT29/03/2017 08:19:03 GMTNotice (6)69011200SW download Successful - Via Config file
29/03/2017 08:15:10 GMT29/03/2017 08:15:10 GMTNotice (6)69010200SW Download INIT - Via Config file tftp file-********
29/03/2017 08:15:06 GMT29/03/2017 08:15:06 GMTError (4)68000407TOD established
29/03/2017 08:13:17 GMT29/03/2017 08:13:17 GMTWarning (5)66050310Auth Success - Web login successful.
The Hub Lights seem to be Normal Power and Ready Solid Blue, Traffic Blinking Blue and the two WIFI lights blinking randomly Blue
  • 10.72K
  • 314
  • 657
Hello again Silentsorrow,
Thanks for the update Smiley Happy
So just so I'm understanding, your connection performs better if you don't do regular reboots?
How has your connection been over the weekend?
Catch you soon,
Take care.
Heather_J
  • 10.04K
  • 332
  • 877
Hero
Their have been posts about this issue and nothing is for sure why...My guess is the way the hubs are build which is a 5 port switch with one port uplinking to the SoC that acks as router mode or modem mode and its the uplinking that drops to 100Mb when you are connected by 1Gb.
