  • 5
johnk68
Message 1 of 5
Monitoring Broadband speed overtime
Hi, can anyone recommend a good software/website I can use to monitor my virgin broadband overtime as I seem to be having random problems with it dropping off and also the speeds?  Thks
  • 362
  • 16
  • 83
pyrotenax
Fibre optic
Message 2 of 5
Re: Monitoring Broadband speed overtime
Apply for a "white box" (which is actually black) , from Samknows site.
https://signups.samknows.com/ofcom/
Running ASUS RT-AC88U with Asuswrt-Merlin firmware
  • 9
albany1
Message 3 of 5
I'm using testmy.net.  If you can leave a device running with a web-browser open (preferably wired directly to a router to get best speeds), you can automate speed tests once/hour.
Thinkbroadband can provide automated latency tests if your router will respond to pings, to give you some idea of connection quality.
You may not like the results!
(1.5Mb/s downstream last night, average pings over 150ms and many dropped packets for me - unusable in any real sense).  Over-Utilisation been going on since September at least. (Area 31 AL3).  The most I ever get in the evening is 5Mb/s.  CS say it will be fixed beginning Feb., now end Feb etc....  You get the picture
  • 5
johnk68
Message 4 of 5
I have registered for a box, how long does it normally take?
  • 362
  • 16
  • 83
pyrotenax
Fibre optic
Message 5 of 5
It seems a bit random tbh . I just registered and forgot about it.
Approx 4 weeks later I got an email saying my box was on the way.
