  • 8
SpAceAce70
Message 1 of 8
Major speed loss using a VPM with Superhub3
Hi. Has anyone had and solved the virgin media superhub 3 problem with using a vpn?
I have 200mbps broadband, but only get a max of 25mbps using ANY paid vpn. I have digibitVPN at the moment, but have tried all the best VPN's around.
I've spoken to virgin media and they say they are aware of the problem and it will be resolved in the next update. But they have been saying that for a couple of years now.
Any help and advice would be greatly appreciated. Thank you.
  • 10.02K
  • 332
  • 877
Hero
Message 2 of 8
Re: Major speed loss using a VPM with Superhub3
Run the following speed test without a VPN to see you x1 TCP speed.
http://www.thinkbroadband.com/speedtest
all VPN's use a single tunnel connection so the gateway QoS treats as a single connection for all your connections down the VPN.
  • 8
SpAceAce70
Message 3 of 8
Hi. So I've done that. Now what? I'm not really up on this kinda thing. Cheers
https://www.thinkbroadband.com/speedtest/1502635224329721955
  • 10.02K
  • 332
  • 877
Hero
Message 4 of 8
By the looks of it your using wireless? Which will make the VPN worse so try a wire test.
  • 8
SpAceAce70
Message 5 of 8
  • 10.02K
  • 332
  • 877
Hero
Message 6 of 8
Is that wired without HomePlug - Network Via Mains
  • 8
SpAceAce70
Message 7 of 8
Yes.
  • 8
SpAceAce70
Message 8 of 8
Could someone from the Virgin media team help me with this please? Thank you.
