  • 5
eggie99
Message 1 of 9
Lw signal Level
Hi all
Can someone tell me if my signal level is low , i thin k it is
Ch  Frq       Pow(dBmV)   SNR(dB)     Mod       Chl ID
1307000000      -11.2             34.9             256 qam          42
2323000000-11.934.4256 qam44
3315000000-1234.3256 qam43
4299000000-1234.3256 qam41
5291000000-11.734.4256 qam40
6283000000-12.434.4256 qam39
7275000000-10.735.7256 qam38
8267000000-1135.5256 qam37
9259000000-9.935.7256 qam36
10251000000-1035.7256 qam35
Eggie
Helpful Answers
  • 5.34K
  • 270
  • 1.17K
Message 2 of 9
Re: Lw signal Level
Yep, much too low. Either ring VM up on 150 and get them to send an engineer out for it, or leave the thread for a couple of days and a VM rep will get to the thread and reply to you.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
All Replies
  • 5.34K
  • 270
  • 1.17K
Message 2 of 9
Re: Lw signal Level
  • 5
eggie99
Message 3 of 9
Re: Lw signal Level
Hi Shaf
I thought they were too low thanks for the info, will leave it a couple of days and see what happens if not then will ring VM.
Eggie
  • 5.34K
  • 270
  • 1.17K
Message 4 of 9
Re: Lw signal Level
Just don't reply to the thread (even to me now!) any more then as VM reply to the oldest posts first, it's a roughly 2 day wait from your last post.
  • 10.82K
  • 308
  • 631
Message 5 of 9
Re: Lw signal Level
Hi eggie99
I appreciate your query in regards to your power levels.
As Shafreya mentioned the downstream power levels are too low. I did also check on your connection and the upstream power levels are getting high as well. For this I can arrange for an engineer to adjust these for you. I've sent you a PM (purple envelope icon, right corner) with some details for you to confirm please. Once you have replied I can go ahead with the appointment.
Hope to hear from you soon
Sam
  • 5
eggie99
Message 6 of 9
Re: Lw signal Level
Been awhile now experiencing low signal levels and very slow speeds my contract is for 200Mb broadband and only getting about 29Mb see below could not copy and paste so typed it out.
Power
Ch  Frequency(Hz)  (dBmV)  SNR (dB)  Modulation    Channel ID
1     323000000        -5.2         35          256 qam             44
2    315000000        -5            35           256 qam             43
3    307000000        -5            35.7        256 qam             42
4    299000000        -5.2         35.5        256 qam             41
5    291000000         -5.4        35           256 qam             40
6    283000000         -5           35.7        256 qam             39
7    275000000         -4.5        36.6        256 qam             38
8    267000000         -4.2        36.6        256 qam             37
9    259000000         -4.2        36.3        256 qam             36
10  251000000         -3.9        36.3        256 qam             35
BETA
Skip to start speed test
Virgin Media Wolverhampton
Change Host
Virgin Media
82.40.216.116
Your speed test has completed.
Your download speed is , 28.65 Mbps
Your upload speed is , 6.89 Mbps
and your ping time took 9 ms
Thank you for using Ookla Speedtest.
Z ahmed
  • 5.34K
  • 270
  • 1.17K
Message 7 of 9
Re: Lw signal Level
The signal range is still within spec.
How are you testing? Wired/wirelessly?
  • 5
eggie99
Message 8 of 9
Re: Lw signal Level
I am.yesting wires with Ethernet connection. If levels are within spec so why is my speed way way too low I am on 200Mb but only getting about 29Mb. Any ideas on that.
Z ahmes
  • 5.34K
  • 270
  • 1.17K
Message 9 of 9
Re: Lw signal Level
Too many people signed up to the services maybe?
Christmas overload? (everyone is home and trying to download their games etc, happens every year)
If you are wired up getting those speeds and your power levels are fine there is nothing really the community can elsewise say, will be a wait for VM to confirm.
