  • 22
ajf
Message 1 of 7
Lower speeds than normal
I am experiencing some low speeds at the moment, relative to the package supplied.
It is the Vivid 200 Gamer so 200mb down and 20mb up.
Typically running at 80-90mb down and 15mb up.
It is a Super Hub3 in modem mode. I have done the usual and powered off for 5 minutes and rebooted modem, then router, then PC (which is hardwired).
I've attached a link to a pdf of the router status.
 https://1drv.ms/b/s!AtMnu1DjoPOwgqtIylKua1iDuxkW_w
  • 22
ajf
Message 2 of 7
Re: Lower speeds than normal
Anyone from Virgin care to respond to this?
It appears from the numerous posts I am not alone in having speed issues, so what is happening and when are you going to be resolving these problems?
  • 22.22K
  • 845
  • 3.23K
Message 3 of 7
vm can take about a week to reply.
are you connecting wireless or wired?
If you open network and sharing center and click adapter settings on the left. right-click on your network adapter you use and click status. what does the speed say?
  • 22
ajf
Message 4 of 7
Thanks for the reply.
I'm using a wired connection connected at gigabit speed to a Netgear Nighthawk router.
However I did try straight into the router after putting it back into router mode and the speeds were roughly the same - certainly not enough difference to indicate it could be the Netgear.
I has been fine up until 2-3 weeks ago when I noticed a drop off.
  • 22.22K
  • 845
  • 3.23K
Message 5 of 7
speeds of 80-90 look like a 100mbps network connection. It may be faulty cabling or drivers. are you sure the connection is at 1gbps. that is why i recommended checking. As i recommended i noticed since i reinstalled on Tuesday mines only at 100mbps so it can happen Smiley Tongue
Now i got to look at mine as well Smiley Sad
  • 8.28K
  • 354
  • 581
Message 6 of 7
Hi ajf,
Thanks for posting!
Really sorry to hear you're having speed trouble.
How did you get on with apcyberax's advice?
I've run a diagnostic on your equipment and everything is looking health at the moment. It does seem the hub hasn't been rebooted for a while, I'd recommend switching it off at the mains for a minute then booting it back up.
Let me know if you're still having trouble and I'll check it out.
Speak soon Smiley Very Happy
Josh
  • 22
ajf
Message 7 of 7
Apologies I haven't replied sooner.
The issue for whatever reason seems to gone for now, and both download and upload are as expected.
No changes were made as I could find nothing wrong with my settings/router, however I had restarted the modem so maybe it was simply that.
Anyway, problem solved Smiley Happy
Andrew
