  • 6
jackydog
Low speed on connected devices
Hi all. I am currently paying for vivid 150 and am getting 150Mbps plus on my main pc which is hard wired about 1 meter from the router.This is obviously great but my problem is with my android tv boxes which both have hard wired connections -one approx 25 meters and t'other about 10meters from router.They both struggle to get 20Mbps.I also have a wireless laptop and 2 wireless pcs which also struggle to achieve 20Mbps.I must emphasize that these speeds are the same when all the other gear is switched off.
Are there any settings on the router-its a super hub 3-that can improve this?
  • 22.23K
  • 845
  • 3.23K
Re: Low speed on connected devices
the wired connection wont be effected by speed. network cable can be a max of 100m.
If you are getting the same on the andoird TV box as you are on other wireless it sounds like the andorid tv box is using the wireless.
  • 6
jackydog
No its deffo wired as the wireless is turned off.When it is in wireless mode the speed is just slightly less
  • 10.82K
  • 308
  • 632
Hi jackydog,
Sorry to read you are having an issue with the broadband speeds.
You mentioned that the wireless is turned off, is that within the Android Box settings?
Are you able to complete a speed test whilst the Hub modem mode please? This will eliminate other devices connected.
Let us know how you get on
Sam
  • 6
jackydog
Yes the wireless is turned off in android settings.As a matter of interest I am using some old (pre cat 6) cable-will that make any difference?
  • 10.82K
  • 308
  • 632
Hi jackydog,
Thanks for getting back to me.
In regards to the Cat 6 cable you are using, it is up to you if you want to try a new cable to see if that will help. However you are getting the correct speeds on your PC, so it might not be the cable itself at fault.
Did you mange to try a speed test whilst in modem mode at all?
Speak soon
Sam
