  • 9
CartoonHead
Low Speeds
I am going to call customer service as I have been experiencing low speeds of late. I am not prepared to go through all the things I have already checked internally so will just cancel if they won't play ball. However, I have noticed that my signal levels seem high. Could this be a factor? Shouldn't they be around 0? I am on the Hub 3.0 and Vivid Gamer and am getting under 100Meg a lot of the time. It used to be a constant 220/21 on speed tests. Downstream values below: Thanks in advance. Channel Frequency(Hz) Power (dBmV) SNR (dB) Modulation Channel ID 1 299000000 7.8 37.3 256 qam 17 2 323000000 8.4 37.3 256 qam 20 3 315000000 8 37.6 256 qam 19 4 307000000 7.5 37.6 256 qam 18 5 291000000 7.5 37.6 256 qam 16 6 283000000 7.3 37.6 256 qam 15 7 275000000 7.5 37.3 256 qam 14 8 267000000 7.3 37.6 256 qam 13 9 259000000 6.8 37.3 256 qam 12 10 251000000 7 38.6 256 qam 11
  • 10.66K
  • 313
  • 657
Re: Low Speeds
Hello CartoonHead,
Sorry to hear about your connection problems. Checking your service from our end I can see that your SNR levels aren't looking great. Let's arrange for an engineer to call around to investigate further. I'll drop you a PM (purple envelope, top right) to confirm a visit.
Speak with you soon,
Take care.
Heather_J
