  • 7
vaktyuk
Lagg
Hi There,
I have problem with my internet connection. Lot of time is lagging or very high latency when i playing on the internet. I play Armored Warfare and Squad. I have a bit much Pre RS errors. My computer use a wired connection to my modem. I made reset my modem lot of times, but no change.PreRSErrors.jpgAn other proof to the lagging connection on the next link:
http://www.thinkbroadband.com/ping/share/786c86021b145a057754f7c9b7225efa-24-11-2016.html
786c86021b145a057754f7c9b7225efa-24-11-2016.pngCould you check my connection, or give me an other advice please!
  • 5.33K
  • 269
  • 1.17K
Re: Lagg
Something is happening every 6 hours.
Your connection definately looks broke though.
Can you post your upstream power levels as well?
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
  • 7
vaktyuk
Re: Lagg
http://www.thinkbroadband.com/ping/share/af3ae663f6b4e5cba6aec0213ef84865-26-11-2016.html
