Dearestjana
Keep getting disconnected from wifi
Cold any one tell me why my wifi keeps disconnecting and the lights on the hub start flashing
  • 9.36K
  • 799
  • 1.96K
Re: Keep getting disconnected from wifi
If the hub's lights start flashing then it is probably the hub disconnecting from VM's servers.
Do any connections connected directly to the hub loose connection?
Posting some basic diagnostic info may help.
Navigate to the hub's GUI using http://192.168.100.1
Don't log in, click the Router Status button in the top right of the screen.
Copy \ Paste the Downstream, Upstream, and Network Logs.
Don't worry about the formatting, but do obscure personal information like your WAN IP address.
  • 10.66K
  • 313
  • 657
Hello there Dearestjana,
Thanks for posting and a warm welcome to the community Smiley Very Happy
Great to see new members!
Sorry to hear about your wireless connection problems, it sounds frustrating. Checking your connection I don't see anything obviously wrong. For that reason I think it would be a good idea if you tried to change your wireless channel. Often this will help with problems caused by wireless interference.
Please let us know if this helps,
Take care.
Heather_J
