  • 68
  • 5
TobyTyler77
Dialled in
Message 1 of 7
Internet speed .
My Hardwired Computer gives me readings of 87mbs download and 11 upload, I'm paying for 200, an engineer called this morning done some adjustments and received 211 mbs, 20 minutes after he left it's gone back to 87 mbs, does anyone know why, and what can i do about it ?
  • 8.8K
  • 600
  • 1.74K
Message 2 of 7
Re: Internet speed .
87 sounds like you have a 10/100 Ethernet card in your PC to receive 200 you need a 1 gig card
  • 770
  • 14
  • 120
tommey
Well-informed
Message 3 of 7
TobyTyler77 wrote:
My Hardwired Computer gives me readings of 87mbs download and 11 upload, I'm paying for 200, an engineer called this morning done some adjustments and received 211 mbs,  < < On his or your equipment?
20 minutes after he left it's gone back to 87 mbs, does anyone know why, and what can i do about it ? < < If you answered his above then is your equipment capable of speeds over 100mbs, do you have gigabit ethernet?
Also please post some connection stats and possibly set up a broadband quality monitor see here
This is the poor quality of my Superhub 3 connection Smiley Sad
My Broadband Ping - Vivid 200 Gamer
- First reported 09/2014 - Fault ticket raised 01/01/15 -    - Review 01/05/15 - Review 12/08/15 - Review 14/10/15 - Review 04/11/15 - Review 15/04/16 - Review 06/07/16 - Review 31/09/16 - Review 30/11/16 - Review 15/02/17 - Review 12/07/17 - Review 20/09/17 - Review 14/06/17 - Review 10/01/18 - Review 25/04/18 - F004670584 << 3 YEARS+
But with BT Fibre I can actually game without lag Smiley Very Happy
My Broadband Ping - BT FIBRE 80/20
  • 68
  • 5
TobyTyler77
Dialled in
Message 4 of 7
Thankyou, i will get the card checked out asap.
  • 770
  • 14
  • 120
tommey
Well-informed
Message 5 of 7
If you are on a windows PC just look in control panel / device manager / network adaptors
Or
Control Panel \ Network and Internet \ Network and Sharing Centre
then on the right side you should see something like this
dfgdfgdfgdfgdfdgfgre.PNGMine is called VM yours will most likely be something different but just click on it and you will see something like this
As you can see mine says Speed: 1.0 Gbps
Let us know how you get on
  • 68
  • 5
TobyTyler77
Dialled in
Message 6 of 7
Thanks for. Your help, luckily it turned out to be a faulty ethernet cable between the modem and computer, it's all fixed now and didn't cost much thankfully. ☺
  • 770
  • 14
  • 120
tommey
Well-informed
Message 7 of 7
So glad you got it all working
