  • 36
rotty66
Message 1 of 10
IPTV freezing and stuttering, broadband def the cause
I am trying to use IPTV and it just stutters and freezes all the time, does same on TV and tablet
If I disconnect from broadband and tether through my phone all is well so it's def the broadband or router
I have 200Mb service and speedtests all seem ok
I have tried it wired and wifi and it's the same
Hope someone can help resolve this as I need this to work and would hate to have to change supplier after 20+years
  • 36
rotty66
Message 2 of 10
Re: IPTV freezing and stuttering, broadband def the cause
seems to be a def broadband issue, tried to download a file from the iptv server under their instruction and was getting 300k transfer, did it from a different broadband and speed was massive
lots of packet loss
 1    <1 ms    <1 ms    <1 ms  routerlogin.net [192.168.0.1]
  2     9 ms    11 ms    10 ms  10.126.144.1
  3    11 ms    14 ms     8 ms  nott-core-2a-ae7-1247.network.virginmedia.net [62.255.231.37]
  4     *        *        *     Request timed out.
  5     *        *        *     Request timed out.
  6    23 ms    22 ms    21 ms  nrth-ic-1-ae1-0.network.virginmedia.net [62.254.42.218]
  7    22 ms    27 ms    26 ms  m674-mp2.cvx1-b.lis.dial.ntli.net [62.254.42.162]
  8    22 ms    26 ms    26 ms  ix-ae-7-0.tcore2.LDN-London.as6453.net [80.231.62.5]
  9    30 ms    32 ms    32 ms  if-ae-26-2.tcore1.LDN-London.as6453.net [80.231.62.58]
 10    32 ms    28 ms    34 ms  if-ae-17-2.tcore1.L78-London.as6453.net [80.231.130.129]
  • 36
rotty66
Message 3 of 10
Go the host folks to load a testfile on server
I download at 300-500k and a friend who is local gets 6MB+ on his BT connection
Really need to get this sorted but don't know how to go about it, tried the 150 helpline but they seemed out of their depth
Don't want to change provider after all these years but if I can't get it resolved I won't have a choice Smiley Sad
  • 36
rotty66
Message 4 of 10
Enginner been out, cganged modem and lowered signal, far too hight apparantly
No better
Its ok at obscure times but evenings and weekends it goes down to a crawl, have tried parallel connections on BT and tethered through a mobile and they are fine so has to be the VM network, no idea how to progress this but I need to get it sorted asap
  • 36
rotty66
Message 5 of 10
does anyone have any idea how I can progress this?
been on to chat several times and the last they did was say it would be escalated and they would get back to me by the 26th, they haven't
just making a last appeal before I call them to cancel and move to BT
  • 22.23K
  • 845
  • 3.23K
Message 6 of 10
do you get better speeds when testing on www.speedtest.net
I can;t see any packet loss from the traceroute you posted.
also it can take about a week to get a vm reply but as you keep posting you are delaying this?
If you get good speeds at other places it might be slow peering with the IPTV servers
  • 36
rotty66
Message 7 of 10
Didn't know how it worked on the forum so will wait a while longer
speedtest if fine even when having issues with this site
re the trace didn't know if the timeouts meant anything
when I have issues with the IPTV service I have tried exactly same thing at same time froother connections ( BT, Voda 4G, pub wifi) and all is fine with speeds20x what I get on VM
  • 10.64K
  • 312
  • 654
Message 8 of 10
Hey there rotty66,
Sorry to hear about the problems you're having with your IPTV, it sounds frustrating.
I've checked your connection and I don't see any issues with your specific connection or the local area.
Is your TV connected wireless or hard-wired? We might need to look into allowing access to certain ports, I know we have to do this sometimes to use IP phones. Are you able to find out what ports you'd need access too?
Catch you soon,
Take care.
Heather_J
  • 36
rotty66
Message 9 of 10
hi
thanks for the reply and sorry for the slow reply, I have been away for 3 weeks
The equipment is hard wired, it is just a http server so I assume all on port 80 and the fact it is fine outside of peak hours would suggest it's not a port issue
at times when I have the issue (evenings and weekends) the connection speed to this site drops by over 95% , I have tried same equipment at same times using BT/ 4G and public wifi connections and all is fine , only on VM is it an issue, I suspect something along the route between me and the site is the issue
In late December the online chat people said they had escalated to 2nd line I have just been back onto them and it seems this was not done from what they could see
I will give it a couple more weeks but it looks like I will have to change provider to resolve which would be a shame as I have used VM (and predecessors) for well over 20 years
  • 14.45K
  • 641
  • 1.46K
Moderator
Moderator
Message 10 of 10
Hi Rotty66,
Thanks for responding. I've checked your connection again and still can't see anything to cause this. As it's only happening with that particular site at those times it could be routing issue. The trace you've posted back in december looks perfectly fine. Could you run another for us at the time you're seeing these speeds and posting it here for us to take a look? It may also be worth running one when you're not seeing the slow speeds for comparison.
