dark-photon
I often get disconnects and slow-downs, are my levels okay?
Quite often my internet will cut out or go very slow. I'm wondering if there is something possibly wrong with the power levels, hopefully you guys can tell.
Screen Shot 2017-04-04 at 18.33.54.pngScreen Shot 2017-04-04 at 18.33.59.png
Thank you for your help, its much appreciated. If there is an issue I'll have to give virgin a bell.
  • 8.32K
  • 357
  • 586
Re: I often get disconnects and slow-downs, are my levels okay?
Hi dark-photon,
Welcome to the Community!
Really sorry to hear you're having trouble with your connection.
I've run diagnostics on your equipment and I can see an issue with both your Upstream and Downstream Power levels that will need to be adjusted. I've sent you a private message (purple envelope at the top right of your screen) so I can arrange for a technician to check it out for you.
Speak soon Smiley Very Happy
Josh
