  • 56
Tizzmanizz
Message 1 of 13
Hub3 VDSL router!
I'm looking to buy a reliable vdsl router because the hub3 is dodgy. I only need the router for my PS4 so being wireless or having other devices connected to it isn't a concern. My hub3 will be used in modem mode. Any suggestions?
  • 22.23K
  • 845
  • 3.23K
Message 2 of 13
Re: Hub3 VDSL router!
you can not use a vdsl router it has to be a cable router.
  • 1.46K
  • 87
  • 343
cje85
Knows their stuff
Message 3 of 13
It doesn't have to be a 'cable' router as such, just a standard router like those offered by ASUS and Netgear with no modem inside.
ASUS are very good.
  • 56
Tizzmanizz
Message 4 of 13
I read somewhere that fibre optic broadband needs a VDSL router and normal broadband runs on a cable adsl router??
  • 17.65K
  • 1.64K
  • 3.07K
Message 5 of 13
That's for broadband down your phone line, not for cable based broadband.
  • 56
Tizzmanizz
Message 6 of 13
If you work for virgin then I'm sure your aware of the hub3 problems. What type of router would you recommend for my specific needs? I have the 200 gamer package that's ONLY used for the PS4 with a cable connection so having numerous devices or wireless signal is irrelevant.
  • 5.64K
  • 289
  • 1.25K
Message 7 of 13
Makes no difference what you have as it all has to go through the hub3 anyway. Just because you would be going to a 3rd party router after the hub3, doesn't mean you will change the hub3 issues.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
  • 56
Tizzmanizz
Message 8 of 13
Can I change the hub3 then or can virgin send me the previous model or a model that works?
  • 5.64K
  • 289
  • 1.25K
Message 9 of 13
You can ring up and ask, probably best to speak to retentions or cancellations as the scripts of offshore won't understand your query.
As they want everyone on a 3, they might (and is within their right to) say no
  • 453
  • 9
  • 90
Bestie
Fibre optic
Message 10 of 13
I suggest this router: http://www.netgear.co.uk/home/products/networking/wifi-routers/R8500.aspx
Nice and stable for me when using the SH3 in Modem mode ( well in the day time anyway due to peak time congestion )
also has good parental controls.
