  • 9
Poundy84
How long?
Just had a new Hub 3 arrive as my other one broke. Came via courier therefore I have set it up. Called number and they have switched. However he said the speed will be very slow until it is fully switched over.
My question is how long does this take?
I am not getting either 1mb speed and should be getting 200mb. Been couple of hours now and not getting any quicker. Switched back to my 4G on my phone until this is sorted
  • 5.63K
  • 287
  • 1.24K
Re: How long?
Once it's activated it should be full speed straight away unless there is a fault in your area.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
