  • 5
sole
High latency and poor speeds PO15 6 area - ongoing problem.
This issue seems to raise it's head every so often, is particularly bad this time making connection almost unusable - more than likely going to leave to an FTTC type connection.
Previously the fault was traced back to Cosham exchange, the below posted MTR looks to show the same Cosham exchange at fault.
Another reason I am looking to move supplier is the price I am paying now I should be on your 200mbps package and would still have change!  I am on a 60mbps with 3mbps upload package with poor stable performance and feel ripped off and annoyed that VM don't look after their long term customers.
Anyway, last ditch attempt to fix this,
Ping to google, direct cable feed to router with no other traffic.
Reply from 8.8.8.8: bytes=32 time=1090ms TTL=56
Reply from 8.8.8.8: bytes=32 time=1147ms TTL=56
Reply from 8.8.8.8: bytes=32 time=862ms TTL=56
Reply from 8.8.8.8: bytes=32 time=215ms TTL=56
Reply from 8.8.8.8: bytes=32 time=275ms TTL=56
Reply from 8.8.8.8: bytes=32 time=565ms TTL=56
Reply from 8.8.8.8: bytes=32 time=562ms TTL=56
Reply from 8.8.8.8: bytes=32 time=643ms TTL=56
Reply from 8.8.8.8: bytes=32 time=660ms TTL=56
Reply from 8.8.8.8: bytes=32 time=696ms TTL=56
Reply from 8.8.8.8: bytes=32 time=597ms TTL=56
Reply from 8.8.8.8: bytes=32 time=807ms TTL=56
Reply from 8.8.8.8: bytes=32 time=953ms TTL=56
Reply from 8.8.8.8: bytes=32 time=1109ms TTL=56
Reply from 8.8.8.8: bytes=32 time=974ms TTL=56
Reply from 8.8.8.8: bytes=32 time=996ms TTL=56
Reply from 8.8.8.8: bytes=32 time=1044ms TTL=56
Reply from 8.8.8.8: bytes=32 time=1019ms TTL=56
Reply from 8.8.8.8: bytes=32 time=1011ms TTL=56
Reply from 8.8.8.8: bytes=32 time=1009ms TTL=56
Reply from 8.8.8.8: bytes=32 time=1086ms TTL=56
Reply from 8.8.8.8: bytes=32 time=1021ms TTL=56
Reply from 8.8.8.8: bytes=32 time=586ms TTL=56
Reply from 8.8.8.8: bytes=32 time=354ms TTL=56
Reply from 8.8.8.8: bytes=32 time=479ms TTL=56
Reply from 8.8.8.8: bytes=32 time=537ms TTL=56
Reply from 8.8.8.8: bytes=32 time=568ms TTL=56
Reply from 8.8.8.8: bytes=32 time=656ms TTL=56
MTR:
Keys: Help Display mode Restart statistics Order of fields quit
Packets Pings
Host Loss% Snt Last Avg Best Wrst StDev
1. ???
2. cosh-core-2a-xe-010-0.network.virginmedia.net 0.0% 72 156.5 102.2 10.3 285.3 70.5
3. ???
4. ???
5. manc-bb-1d-ae0-0.network.virginmedia.net 0.0% 71 112.4 101.6 16.6 291.8 72.1
6. know-dcore-1b-pc1.network.virginmedia.net 0.0% 71 132.6 107.1 19.2 272.7 71.0
  • 10.82K
  • 308
  • 631
Re: High latency and poor speeds PO15 6 area - ongoing problem.
Hi sole,
Thanks for taking the time to post on the community. It's nice to have you back here.
I'm sorry to read that you are having issues with high latency and slow broadband speeds.
Looking at your connection, I am unable to see any apparent issues on the network that would cause these issues for you. There are no faults reported and the traffic on the network is running stable.
It may be worth giving us a ring on either 150 free from a Virgin Media landline or 03454 454 1111 to upgrade your Ambit 300 to one of our Super Hub's. As you will benefit from the extra downstream and upstream channels.
Let me know how you get on
Sam
