MarkOnline
HELP: Consistently slow evening DL speeds - Normal upload speeds
Hey guys,
I've been having a recurring problem since around November time with my download speeds tanking after about 5pm and picking back up around midnight or the morning after. My upload speeds aren't affected strangely and I can't think of a problem my end that could be causing the issue.
I've signed in and ran the service test with no issues, I've restarted all my equipment numerous times and there are no broadband issues in my area either, the only thing that has changed over the last 3-4 months is I had the new Super Hub 2 router installed (all the connections feel absolutely solid and secure).
I'm assuming that there might be a data overload on my line as I've stumbled across this issue on other forums too, or that it may be the local cabinet is due for an upgrade/maintenance, although I'm crossing my fingers that's not the issue!
As you can see from some of my speed records, the DL tanks at roughly the same time but the speeds are great first thing and around lunch time. Like I said these records go back to at least 20th November. I can barely stream videos or chat on the PS4 every evening now and it's getting really annoying considering I'm paying in excess of £50 a month for this 'service'.
Here are my latest downstream channels:
Downstream Channels Lock Status Channel ID Frequency Modulation Rx Power RxMER Pre RS Errors Post RS Errors
Locked9299000000 Hz256 QAM8.7 dBmV 37.6 dB7263297
Locked5267000000 Hz256 QAM9.3 dBmV 37.6 dB8408280
Locked6275000000 Hz256 QAM9.4 dBmV 37.9 dB791293
Locked7283000000 Hz256 QAM9.0 dBmV 37.9 dB693289
Locked8291000000 Hz256 QAM8.7 dBmV 38.3 dB343302
Locked10307000000 Hz256 QAM9.3 dBmV 37.9 dB322300
Locked11315000000 Hz256 QAM9.7 dBmV 37.9 dB324297
Locked12323000000 Hz256 QAM9.7 dBmV 38.3 dB316284
Current Modem Initialisation:
Modem Initialisation Stage Status
Downstream AcquisitionLocked
Primary Frequency299000000 Hz
DHCPDone
TFTPDone
Time Of Day19:59:58 GMT
SecurityBPI+
Counters T1,T2,T3,T4,Sync,Resets000,000,000,000,000,000
Any help would be massively appreciated!
Thanks a lot guys!
Mark.
MarkOnline
Re: HELP: Consistently slow evening DL speeds - Normal upload speeds
UPDATE:
Tested the net again as it's a Sunday (05/02/2017) and the DL speeds are ranging between 2Mb - 4Mb, leading me to believe this is a peak-time related issue.
If so I'll be cancelling my Virgin subscription asap unless they can address the issue with peak time demand, which is a shame as I've been a Virgin customer for about 5-6 years now.
Any help would be really appreciated guys.
Thanks.
MarkOnline
Booted in modem mode and run another speed test - ping seems to be abnormally higher than usual with the peak-time slowdown:
6027162500
(Using direct Ethernet connection)
  • 14.44K
  • 641
  • 1.46K
Moderator
Moderator
Hi MarkOnline,
Sorry to hear you're getting poor speeds. I've checked your connection and can see there is a contention fault in the area under ticket F004392349. This will cause slow speeds at peak times such as evenings and weekends and is due for review 15/03/17.
