  • 33
  • 6
Message 11 of 44 (244 Views)
Re: Gamer 200 speed not great
I spoke to a technician online last night who took over my pc and who checked the stats using the same link saying everything looked fine??? Im bloody confused for its clearly not fine. Im also unable to check the stats on my pc aas Im getting the same refuse to connect bullcrap
  • 33
  • 6
Message 12 of 44 (233 Views)
Downstream:
Downstream bonded channels Channel Frequency(Hz) Power
(dBmV) SNR
(dB) Modulation Channel ID
12990000003.540.3256 qam45
23230000003.540.3256 qam48
33150000003.440.3256 qam47
43070000003.440.3256 qam46
52910000003.540.3256 qam44
62830000003.440.3256 qam43
72750000003.240.9256 qam42
82670000003.740.3256 qam41
92590000003.540.3256 qam40
102510000003.440.3256 qam39
112430000003.540.3256 qam38
Upstream:
Upstream bonded channels Channel ID Frequency(Hz) Mode Power
5746200000ATDMA47.564 qam64000005120
5932600000ATDMA47.564 qam64000005120
Network Log:
Network Log Date And Time Error Number Event Description
2017-04-20 14:04:52.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-20 14:37:18.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-20 14:38:16.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-20 14:42:55.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-20 14:43:03.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-20 14:45:44.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-20 14:46:39.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-20 14:47:08.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-20 14:47:28.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-20 14:48:08.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-20 14:48:24.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-20 14:48:33.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-20 14:48:37.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-20 14:48:41.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-20 14:52:11.0069010200SW Download INIT - Via Config file
2017-04-20 14:52:38.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-20 15:41:36.0069011200SW download Successful - Via Config file
2017-04-20 15:45:57.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-20 18:50:58.002417164308Unit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-20 18:51:19.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 90
  • 8
Message 13 of 44 (706 Views)
confirmed by redzombie
‎21-04-2017 16:36
Red i'm from same area and the engineer told me this, He explained the UBR is over utilized because they have added more areas around us (mullusk, brambles) so they need to upgrade the CMTS, They said they have been told it should be fixed by the 2nd week in May
  • 33
  • 6
Message 14 of 44 (207 Views)
[ Edited ]
I hope so else I'll be cancelling and going elsewhere. Thanks for the heads up 😃
  • 6.86K
  • 165
  • 401
Message 15 of 44 (159 Views)
Hi redzombie,
Thank you for keeping us updated.
I have popped a reply to you in this thread http://community.virginmedia.com/t5/Speed/Area-26-slow-broadband-since-November-2016/m-p/3407226#M16...
But in future I shall pop my replies to you here.
I hope this is ok for you.
Speak to you soon.
Emma
  • 6.86K
  • 165
  • 401
Message 16 of 44 (137 Views)
[ Edited ]
Hi redzombie,
Just a quick update, FECS related fault has now been resolved.
How has the connection been looking for you over the last few days?
If you are continuing to have trouble let us know and we will take another look for you.
All the best
Emma
*edit spelling
  • 33
  • 6
Message 17 of 44 (126 Views)
[ Edited ]
I received a text msg this morning from VM telling me the problem had been resolved. Unfortunately it is still the same, there has been no change in download speeds since I first reported the problem, still hitting around 5/6mb. The last few days I have not seen any difference, infact streaming services like iplayer and netflix have become almost impossible to watch.
(dBmV) SNR
33150000003.240.3256 qam47
52910000003.440.3256 qam44
72750000003.240.3256 qam42
82670000003.540.3256 qam41
122350000003.540.3256 qam37
5746200000ATDMA4864 qam64000005120
5932600000ATDMA4864 qam64000005120
2017-04-30 11:39:16.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-30 14:10:35.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-30 14:10:39.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-30 15:26:29.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-30 15:26:35.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-30 16:04:25.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-30 16:04:37.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-30 16:23:23.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-30 16:23:34.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-30 16:32:52.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-30 16:33:02.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-30 16:37:37.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-30 16:37:44.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-30 16:39:59.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-30 16:40:49.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-30 16:41:10.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-30 16:41:34.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-30 16:42:22.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-30 16:42:24.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-30 16:42:28.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 19
Message 18 of 44 (119 Views)
[ Edited ]
Did you subscribe to a new contract when you changed over to 200mb? I hope not because you'll have to pay Virgin compensation if you try and cancel, which is disgraceful considering they mis-sold you the higher package in an *oversubscribed area (*Virgin have confirmed this to me).
I've got to ring them today to provide my 30 day cancellation notice, which I believe is not the easiest thing to do!
  • 33
  • 6
Message 19 of 44 (110 Views)
Yes I was getting 70mb before the problem started, the 2nd time I rang them they told me I should change to the vivid gamer 200mb deal as it would fix my problem and their would be no capping, they said if I stuck with the 70mb they could not guarantee that I would not be capped the following months so I went ahead and got it I also think its an 18mth contract too Smiley Sad after the problem wasnt solved with the new suberhub3 activated I phoned again and was told that the guy I previously spoke to was in big trouble because he told me I was being charged 49.99 installation fee as I had queried that charge seeing as though no engineer called as we did it ourselves, he should have been in trouble for telling us to take a out the new deal which cost more but no nothing was mentioned about that. yeah they totally mis-sold and mislead me down the garden path. I, paying almost £60 a month its a joke.
  • 19
Message 20 of 44 (106 Views)
You need to look into complaining to whoever will listen and get out of this contract. It sounds (literally) criminal to me.
