  • 33
  • 6
redzombie
Message 1 of 44
Gamer 200 speed not great
I recently changed my broadband to the vivid gamer 200, I recently had 70mb but last week I noticed a drop in speed, between 3 and 5mb, my upload speeds were better, when I phoned VM I was told that my speeds had been capped due to traffic congestion in my area, and that it had been from 18/13/17. I am in area 26 and had no problems until 14th April so they never bothered to tell me back in March they had capped me. They said they would fix it within 24hrs which they did'nt. Another call a few days later and that was when I was offered the 200mb deal, they told me that it would better suit my broadband needs and the household does a lot of gaming etc, was told that there was no capping what the gamer 200 deal. They sent me a superhub 3 and activation went ahead.
My problem is that the download speeds barely go over 5mb  which was the problem in the first place but I am getting the 20mb upload speeds as promised, and that is with ethernet into pc and also wifi, I am doing speed tests every couple of hrs and there is very little difference, 2 more calls to VM and being passed to different departments and the problem has still not been resolved. Does not seem justified paying for a service that you are not getting. I've been  a customer for 7yrs and never had any bother with broadband speeds before but this is taking the cake!! Can anyone help or give advice please?
http://beta.speedtest.net/result/6235630728
Helpful Answers
  • 90
  • 8
bobajob84
Message 13 of 44
Re: Gamer 200 speed not great
Red i'm from same area and the engineer told me this, He explained the UBR is over utilized because they have added more areas around us (mullusk, brambles) so they need to upgrade the CMTS, They said they have been told it should be fixed by the 2nd week in May
  • 20
GuitarJoe
Message 22 of 44
I have had it confirmed that the problem is oversubscription, not a technical fault that can be solved with a few spanners and a multimeter.
The offshore help centre will do nothing but give you the runaround. Switching the hub on and off will not magically upgrade the local exchange!
Technically, Virgin aren't in breach of contract for providing painfully slow speeds - no matter which package you're on - so I would concentrate my complaint on the fact you were 'hoodwinked' into signing a new contract based on the idea that somehow a higher tier package would solve the slow speeds issue.
I would search for the best method of complaining to Virgin, try and find a number that goes straight to a UK based Virgin help desk. Maybe a moderator on here can help you?
Best of luck. Don't give up!
All Replies
  • 896
  • 18
  • 324
pete7049
Well-informed
Message 2 of 44
Sounds like you've been speaking to the offshore call centre. The only time that you would get capped is if you upload lots. There's no cap on downloads unless you've breached the upload limit. As they mentioned congestion, I suspect that you're suffering from over utilisation (Over selling.) in your area. Upgrading to 200 won't make any difference to your speed if you're in an over utilised area, as you'll still be on the same part of the network that can't cope with the demand for bandwidth. Offshore will tell you anything just to get you off of the phone, and to sell you something that costs more than what you had.
F003443743. December '14 - May '17.
  • 33
  • 6
redzombie
Message 3 of 44
That's crazy, yeah I kinda realised they have been passing the buck, after looking at a few others comments on speed from my area they are getting the same problem, one has even said its the core hub.
  • 896
  • 18
  • 324
pete7049
Well-informed
Message 4 of 44
As you're getting slow download speeds after upgrading to 200 Gamer (No upload limits, so no capping.) it's a very good chance that your area is over utilised. Does the drop in speed only happen at peak times ( 16:00 - 00:00, and at all times at weekends.) ? Do you get full speeds off peak?
  • 33
  • 6
redzombie
Message 6 of 44
No not just peak times. its the same over the 24hr period, its sits barely abve 5mb although upload speeds are 20/21mb which what they promised,yeah after talking to people in my area with the same problems it seems that we live in an over utilised area. Im just off the phone to them and they would not admit it just brushed me off again, in it his opinion was the problem was the core hub in my area and that it needs refigured? they are adding more new areas so no wonder there is a lot of congestion, the fact that they got me to upgrade and fork out more money saying it would solve the problem when infact there is no difference so basically I feel like I have been scammed. They have offered a 25% discount on my monthly bill which I demanded as I said they are not delivering the service they promised.
  • 788
  • 14
  • 126
tommey
Well-informed
Message 7 of 44
@redzombie
Do us a favour post your hub stats
This is the poor quality of my Superhub 3 connection Smiley Sad
My Broadband Ping - Vivid 200 Gamer
- First reported 09/2014 - Fault ticket raised 01/01/15 -    - Review 01/05/15 - Review 12/08/15 - Review 14/10/15 - Review 04/11/15 - Review 15/04/16 - Review 06/07/16 - Review 31/09/16 - Review 30/11/16 - Review 15/02/17 - Review 12/07/17 - Review 20/09/17 - Review 14/06/17 - Review 10/01/18 - Review 25/04/18 - Review 08/08/18 - F004670584 << 3 YEARS+
But with BT Fibre I can actually game without lag Smiley Very Happy
My Broadband Ping - BT FIBRE 80/20
  • 9.58K
  • 826
  • 2.01K
Message 8 of 44
Poor speeds all the time is more indicative of a technical problem, rather than a utilsation issue, However, you may have a technical problem masking a utilsation issue.
Posting some basic diagnostic info may help.
Navigate to the hub's GUI using http://192.168.100.1
Don't log in, click the Router Status button in the top right of the screen.
Copy \ Paste the Downstream, Upstream, and Network Logs.
Don't worry about the formatting, but do obscure personal information like your WAN IP address.
  • 896
  • 18
  • 324
pete7049
Well-informed
Message 9 of 44
School holidays at the moment? That'd contribute to off peak slow downs too.
  • 33
  • 6
redzombie
Message 10 of 44
Unfortunately it says site can't be reached in that link
