alexwarren
Frequent dropouts
I've noticed my internet connection dropping out more frequently on Vivid 200. This is on both wired and wireless, and the dropouts occur for a few seconds. It's especially noticeable (and annoying!) if I'm listening to streaming radio. Sometimes an hour can go by with no dropouts, then it can be really flakey for half an hour.
Looking at the Network Log on the router, the dropouts coincide with messages like
  • SYNC Timing Synchronization failure - Loss of Sync
  • RCS Partial Service
  • No Ranging Response received - T3 time-out
Here's the whole log for the last hour or so:
2016-12-17 11:17:11.00	84000500	SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-17 11:17:38.00	84000700	RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-17 11:43:57.00	84000500	SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-17 11:44:06.00	84000700	RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-17 11:51:55.00	84020200	Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-17 11:53:57.00	84000500	SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-17 11:54:10.00	84000700	RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-17 11:54:32.00	84000500	SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-17 11:55:01.00	84000700	RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-17 11:56:16.00	84000500	SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-17 11:56:29.00	84000700	RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-17 12:02:27.00	82000200	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-17 12:02:37.00	84000500	SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-17 12:02:38.00	84000700	RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-17 12:08:55.00	84000500	SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-17 12:09:04.00	84000700	RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-17 12:09:04.00	82000200	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-17 12:09:47.00	84000700	RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-17 12:09:48.00	84000500	SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-17 12:12:28.00	84000700	RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
alexwarren
Re: Frequent dropouts
Other router info if that's useful:
Downstream
Channel Frequency(Hz) Power
(dBmV) SNR
(dB) Modulation Channel ID
13227500001.938.9256 qam40
23147500001.739.8256 qam39
33067500001.740.3256 qam38
42987500001.538.9256 qam37
52907500001.538.9256 qam20
62827500001.739.3256 qam19
72747500002.540.3256 qam18
82667500002.540.9256 qam17
92587500002.240.3256 qam16
102507500002.540.3256 qam15
112427500003.240.3256 qam14
122347500003.240.9256 qam13
Upstream
Upstream bonded channels Channel ID Frequency(Hz) Mode Power
235800000ATDMA43.864 qam64000005120
453700000ATDMA43.864 qam64000005120
145800000ATDMA43.864 qam64000005120
  • 3.88K
  • 120
  • 203
Forum Team (Retired) Adam_L
Hi alexwarren,
Thanks for letting us know about your issues with frequent drop outs, I apologise for any inconvenience caused.
I have tested things from here and I can see a load of T3 time outs inside the Hubs logs, an engineer will need to attend and investigate things further for you.
I will send you a PM (purple envelope at the top) detailing what's required to proceed with making the booking, please respond to me there and I'll get this all sorted for you.
Take care,
Adam.
