scott_1990
Message 1 of 5
Fibre Broadband running very slow.
I have Fibre broadband with virgin which has apparent speeds of 200mbps.
I have been running speed tests for a while and haven't had above 40 mbps. Also today I been experiencing as little as 7mbps.
I have also, since joining virgin been receiving a lot of interruptions to the service which can often keep going off all day.
Is this anything I should be checking for?
P.s. I have posted my router power settings and log below.
Channel Frequency(Hz) Power
(dBmV) SNR
(dB) Modulation Channel ID
1 299000000 1.4 38.9 256 qam 7
2 323000000 0.7 40.3 256 qam 10
3 315000000 1 38.6 256 qam 9
4 307000000 1 38.6 256 qam 8
5 291000000 1.4 38.9 256 qam 6
6 283000000 1.4 38.9 256 qam 5
7 275000000 1.2 38.6 256 qam 4
8 267000000 1.5 38.6 256 qam 3
9 259000000 1.5 38.6 256 qam 2
10 251000000 1.7 38.6 256 qam 1
Channel ID Frequency(Hz) Mode Power
11 27400000 ATDMA 41.3 16 qam 6400000 5120
10 35800000 ATDMA 41.3 16 qam 6400000 5120
Date And Time Error Number Event Description
2016-12-16 11:10:03.00 84000700 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-16 11:18:00.00 84000500 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-16 11:18:00.00 84000700 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-16 11:18:01.00 84000500 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-16 11:18:05.00 84020200 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-16 11:18:41.00 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-16 11:44:39.00 84000700 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-16 11:44:40.00 84000500 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-16 11:44:40.00 84000700 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-16 11:44:44.00 84020200 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-16 11:47:31.00 84000700 RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-16 11:47:31.00 84000500 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-16 11:47:32.00 84000500 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-16 11:47:36.00 84020200 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-21 06:49:50.00 68010100 DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-22 14:19:53.00 68010400 DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-25 14:31:07.00 68010100 DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-26 10:12:25.00 68010400 DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 90
  • 8
bobajob84
Message 2 of 5
Re: Fibre Broadband running very slow.
Good luck mate. heres mine from 11pm tonight
Thats my 300mbit down 20mbit up line which is actually better than what i was getting some nights
virgin
glasgow 90mbit 7mbit
Leicester 128mbit 8mbit
Basildon 118mbit 10mbit
Manchester 126mbit 8mbit
douglas
manx 19mbit 12mbit
preston
boundless 89mbit 11mbit
bt 61mbit 8mbit
liverpool 92mbit 8mbit
Carlisle
Solway 104mbit 8mbit
Gemini 40mbit 8mbit
Dublin
Digiweb 88mbit 9mbit
  • 7
PeteC74
Message 3 of 5
I'm paying for 50mb and currently running at anything between 3mb and max out at 7mb with huge packet loss im in the B62 Halwsowen area
  • 35
haydenbcfc
Message 4 of 5
Atleast you have usable internet, from 3pm to 1am i get less than 2mbps, around 10pm its goes to around 200kbps Smiley Happy
100mbps line
  • 35
haydenbcfc
Message 5 of 5
