  • 18
bmitch92
Message 1 of 7
Fault causing bad speed, would an upgrade solve
I have an outstanding fault due to overusage / subscription in my area, currently on 100mb and get about 5mb, if i went for 200mb would that increase the speed at all?
Helpful Answers
  • 453
  • 9
  • 90
Bestie
Fibre optic
Message 6 of 7
Re: Fault causing bad speed, would an upgrade solve
No! you will put yourself in a new contract and they will gladly fraudulently sell it to you.
All Replies
  • 896
  • 18
  • 323
pete7049
Well-informed
Message 2 of 7
You'd just be paying more for a couple of meg' at best. If your area is over subscribed, upgrading won't help.
F003443743. December '14 - May '17.
  • 126
  • 54
SiKi
Up to speed
Message 3 of 7
No don't, whatever you do don't give them any more money as they will gladly take it off you..
You will still get the same speed.
They are a bunch of crooks most dishonest company i have ever had the dis pleasure of dealing with..
  • 5.63K
  • 287
  • 1.24K
Message 4 of 7
You will get better offpeak speeds, same peak speeds.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
  • 8.6K
  • 437
  • 1.02K
jb66
Message 5 of 7
It would not, you will still get the exact same during peak times
  • 453
  • 9
  • 90
Bestie
Fibre optic
Message 6 of 7
  • 18
bmitch92
Message 7 of 7
Thanks, think ill leave it as is for now then
