  • 20
  • 7
Fishpan
Fault Reference F004974963?
Hi all,
I was recently given a fault reference F004974963 for my area (SM4) but was not provided with much information about this - please can someone take a look and let me know what it concerns and what the estimated fix date is? Much appreciated, thanks.
~Fishpan
  • 5.36K
  • 273
  • 1.18K
Re: Fault Reference F004974963?
Won't have a fix date, it will be a review date only.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
  • 14.38K
  • 640
  • 1.45K
Moderator
Moderator
Hi Fishpan,
I've just checked on your connection and can't see the fault you're referring to but can see that you are affected by fault F004996809. This is for contention in the area which will cause poor speeds at peak times. This is due for review 03/05/17.
