Smas001
Message 1 of 5
Expected Broadband Speed
I pay for 150Mb fibre broadband.  I have a superhub2 router.  I predominantly use a wifi connection on my laptop.
After numerous wired and wireless 'Speedtest.net' speed checks at various times of the day over a period of 2 months I am consistently getting speeds much lower than the 150Mb I pay for.
I understand speed may change due to demand on the network and the method of connection will affect what speeds I receive, but on average I am getting the following speeds:
Wired connection - Max 70Mb download ; Wifi - Max 40Mb download.
Why am I receiving, at maximum, less than 50% of the speed for which I am paying?
Thanks in advance
Helpful Answers
  • 3.01K
  • 383
  • 952
Message 2 of 5
Re: Expected Broadband Speed
Are you sure that the devices you are using to test are capable of higher speeds?  Some wireless devices are limited by their hardware to around 40-50Mbps.
For a wired connection, speeds below 100Mbps per second as you describe are often the result of a hardware limitation. Some PC's have network cards that are limited to 100Mbps (which after overheads gives speeds below 100), or faulty drivers that can limit speed or are not configured correctly, or it could be the Ethernet cable that is limited to 100Mbs by design or is damaged. If the wired connection from the hub to your laptop is showing an orange light on the Ethernet port of your network card, then the hub might only be negotiating a 100Mbs connection.
______________________
Scott
  • 453
  • 9
  • 90
Bestie
Fibre optic
Message 4 of 5
With a 100Mbit network card the most you will get is 90mbps in my exp.
  • 3.01K
  • 383
  • 952
Message 5 of 5
Yes, Google says that is a Fast Ethernet card that is indeed limited to 100Mbps max but will deliver less in the real world.  To get your full 150Mbps you will need something with a gigabit Ethernet card.
Scott
All Replies
  • 3.01K
  • 383
  • 952
Message 2 of 5
Scott
Smas001
Message 3 of 5
Hi Scott,
Thanks for the swift reply.  I don't appear to get the orange light but looking at my network card (Marvell Yukon 88E8040) I think you may be right that the card is limited to 100. Ah well maybe an excuse for some new hardware!
Cheers
  • 453
  • 9
  • 90
Bestie
Fibre optic
Message 4 of 5
  • 3.01K
  • 383
  • 952
Message 5 of 5
Scott
