  • 18
neilg99
Message 1 of 19
Every mid-morning connection drops
Area reference 21
Every day between 10-11am my cable internet will stop working for approx 3 mins. According to the router lights the link is up, no entries in the router logs but the internet just stalls and all devices report no internet.
Service status reports no issues in my area.
  • 2.62K
  • 209
  • 799
Dave_cq
Trouble shooter
Message 2 of 19
Re: Every mid-morning connection drops
Hi Neil,
Are all your devices connected via Wi-Fi?  If so it may be something either in your home or nearby that is on a timer and creating enough radio interference to knock out your connections.  Do you have gas or electricity Smart Meters which may be 'phoning home'.  Changing Wi-Fi channel may be an answer.
********* SuperHub 2ac - Asus rt-ac68u Router - Vivid 100Mbps **********
Electron
  • 18
neilg99
Message 3 of 19
Afraid not, it effects all devices both wireless and cabled.
  • 8.3K
  • 521
  • 2.3K
Message 4 of 19
Check DHCP lease renew interval. Is it set to 24 hrs?
  • 2.62K
  • 209
  • 799
Dave_cq
Trouble shooter
Message 5 of 19
Hi Kippies.   Surely DHCP renewal would show up in the router logs and OP say no log entries ????
Electron
  • 18
neilg99
Message 6 of 19
Im not using DHCP on the VM router.
  • 2.62K
  • 209
  • 799
Dave_cq
Trouble shooter
Message 7 of 19
Is the Hub in Modem mode and which version of the Hub is it.
Electron
  • 8.3K
  • 521
  • 2.3K
Message 8 of 19
AS OP has clarified, its no longer relevant  -but for information.
Your log shows DHCP renewal from CMTS to HUB (WAN IP)
HUB to devices LAN side isn't logged anywhere AFAIK.  So if people have it set to 24hrs and its say 7pm every day it renews the leases,  they will see LAN side "dropping out" every time around 7pm.
@neilg99
Can you set up a BQM so we can see if drops are WAN side?
 HERE
 Run it for say 24 hrs, and post the result.
Dont forget you'll need to make sure your router  is configured to reply to ICMP echo requests...
  • 18
neilg99
Message 9 of 19
In router mode but DHCP is handled elsewhere on the LAN.
Hub is VMDG490 Superhub 2ac ?
  • 18
neilg99
Message 10 of 19
Will do.
