sadsmileyface
Message 1 of 5
Ever-decreasing speed on VIVID 200 Optical Fibre... more like ADSL2
I've been on VIVID 200 Optical Fibre for a while now and have noticed that speeds have been quietly been reducing. It's not enough to stop me from using the internet at all, but it's enough to cause me to question what I'm paying for. I know that I'm not going to get 200 Mbps, but 12 Mbps is absolutely not what I'm paying for.
I've carried out an online fault test through the website and it's came back clear.
I have a Virgin Media Super Hub 2ac which is connected to my PC through Ethernet. I have an iPad connected through WiFi which delivers the same experience.
Can anyone spot anything amiss here?
Downstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 315000000 267000000 275000000 283000000 291000000 299000000 307000000 323000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 11 5 6 7 8 9 10 12
Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV) 5.88 7.30 7.22 6.48 6.33 6.31 6.07 5.66
RxMER (dB) 38.26 38.26 38.26 37.94 38.98 38.61 38.61 38.61
Pre RS Errors 10604 13616 8827 2202 355 301 898 965
Post RS Errors 315 964 295 943 331 294 880 958
Upstream   US-1 US-2 US-3 US-4
Channel Type 2.0 N/A N/A 2.0
Channel ID 19 N/A N/A 17
Frequency (Hz) 32600000 N/A N/A 46200000
Ranging Status Success N/A N/A Success
Modulation 32QAM N/A N/A 32QAM
Symbol Rate (Sym/sec) 5120000 N/A N/A 5120000
Mini-Slot Size 4 N/A N/A 4
Power Level (dBmV) 39.75 N/A N/A 39.50
T1 Timeouts 2 2 2 2
T2 Timeouts 0 0 0 0
T3 Timeouts 1 0 0 0
T4 Timeouts 0 0 0 0
First Time Last Time Priority Error Number Description
25/03/2017 10:46:55 GMT 25/03/2017 10:46:55 GMT Warning (5) 66050310 Auth Success - Web login successful.
22/03/2017 14:22:51 GMT 22/03/2017 14:22:51 GMT Error (4) 68010302 DHCP WAN IP - ##########
22/03/2017 14:22:21 GMT 22/03/2017 14:22:21 GMT Error (4) 68000407 TOD established
22/03/2017 14:22:09 GMT 22/03/2017 14:22:09 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
22/03/2017 14:22:02 GMT 22/03/2017 14:22:02 GMT Notice (6) 84000510 Downstream Locked Successfully
22/03/2017 14:21:28 GMT 22/03/2017 14:21:28 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
22/03/2017 13:00:10 GMT 22/03/2017 13:00:10 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
22/03/2017 10:17:33 GMT 22/03/2017 10:17:33 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
22/03/2017 04:52:20 GMT 22/03/2017 04:52:20 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
21/03/2017 18:01:50 GMT 21/03/2017 18:01:50 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
18/03/2017 10:32:19 GMT 18/03/2017 10:32:19 GMT Error (4) 68010302 DHCP WAN IP - #########
18/03/2017 10:31:59 GMT 18/03/2017 10:31:59 GMT Error (4) 68000407 TOD established
18/03/2017 10:31:48 GMT 18/03/2017 10:31:48 GMT Warning (5) 68000401 ToD request sent - No Response received
18/03/2017 10:31:40 GMT 18/03/2017 10:31:40 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
18/03/2017 10:31:32 GMT 18/03/2017 10:31:32 GMT Notice (6) 84000510 Downstream Locked Successfully
18/03/2017 10:30:57 GMT 18/03/2017 10:30:57 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
18/03/2017 08:39:05 GMT 18/03/2017 08:39:05 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
18/03/2017 04:55:21 GMT 18/03/2017 04:55:21 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
17/03/2017 21:27:50 GMT 17/03/2017 21:27:50 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
17/03/2017 06:32:53 GMT 17/03/2017 06:32:53 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
  • 1.46K
  • 87
  • 344
cje85
Knows their stuff
Message 2 of 5
Re: Ever-decreasing speed on VIVID 200 Optical Fibre... more like ADSL2
Everything looks OK there, a few timeouts on the upstream but they're unlikely to be the cause of major speed reductions.
Have you ever reached 200Mb? If not, what is the best speed you've seen?
It's possible that there is congestion in your area which would affect the speeds at peak time, but on Virgin it should always be possible to reach the headline speed at some point during the day. If you've never been able to achieve 200Mb there is definitely something wrong.
sadsmileyface
Message 3 of 5
I've noticed that when using FTP, download speed is normally sitting at somewhere about 340Kibp/s, but when I connect through VPN, it mysteriously shoots up to 1.1MiB/s.
sadsmileyface
Message 4 of 5
Really disappointed to see this still going on.
Speed of 60.KiB/s tonight.
Turn the VPN on, whoosh up to 3.0 MiB/s.
  • 10.66K
  • 313
  • 657
Message 5 of 5
Hey sadsmileyface,
Sorry to hear about the problems with your connection. I've taken a look and I don't see any immediate issues. Are you able to test your network while connected in modem mode? Please post back to us with your results.
Take care.
Heather_J
