mjs121
Erratic speeds after upgrade from Fibre50 to Vivid200
We have recently upgraded from Fibre50 to Vivid200 & an engineer visited to fit a TiVo box. Our download speeds are now very erratic. On Fibre 50 i used to get a rock solid 50Mbps at all times of the day but now speeds can vary from anywhere between 30 & 225Mbps - becoming very erratic in the evening.
I know the network can get congested at peak times but something doesn't seem quite right here as download speeds are now often slower in the evening on Vivid200 than they used to be on Fibre50.
Here are some speedtest.net results taken in quick succession last evening using a wired connection. Download (Mbps): 42, 64, 34, 92, 41, 147, 32, 140, 97, 213. Ping 17-23ms. Upload 12 Mbps. Results using wireless devices are even more all over place.
We've also had the occasional error message on our TiVo box in the evenings (W02 "There is a problem with the signal on this channel").
I include my superhub stats below. Any help much appreciated.
Channel Frequency(Hz) Power
(dBmV) SNR
(dB) Modulation Channel ID
1 322750000 14.5 36.6 256 qam 112
2 314750000 14.5 36.6 256 qam 111
3 306750000 14 36.6 256 qam 110
4 298750000 14.1 36.6 256 qam 109
5 290750000 13.6 36.6 256 qam 92
6 282750000 13.8 37.3 256 qam 91
7 274750000 13.8 37.6 256 qam 90
8 266750000 13.1 37.3 256 qam 89
9 258750000 12 36.6 256 qam 88
10 250750000 10 36.3 256 qam 87
11 242750000 10.4 36.3 256 qam 86
12 234750000 15.1 37.3 256 qam 85
Channel ID Frequency(Hz) Mode Power
2 39400000 ATDMA 43 64 qam 6400000 5120
3 32600000 ATDMA 43 64 qam 6400000 5120
1 46200000 ATDMA 43 64 qam 6400000 5120
Thanks.
  • 3.14K
  • 36
  • 601
Ignition
Trouble shooter
Re: Erratic speeds after upgrade from Fibre50 to Vivid200
Your downstream power levels are too high. This will need fixing. Did you ever have a forward path attenuator attached anywhere?
mjs121
Thanks for reply. Not to my knowledge - the superhub has always been connected directly to the wall socket with a standard piece of cable.
  • 14.45K
  • 641
  • 1.46K
Moderator
Moderator
Hi Mjs121,
Welcome to the forum and sorry to hear you're getting poor speeds. I've just checked your connection and can see that there is currently a SNR fault open in your area. This is under ticket F005084164 and is estimated to close today (15/02) at 6pm.
SNR faults can affect your power levels so even once the fault is closed it'd be worth posting your power levels again and we can re check for you.
