  • 35
jellyroll
Message 1 of 19
David, you're flying at your new speed ... or not?
On 11/8, I received an e-mail with the heading above to tell me that my speed had been increased from 152 Mbps to 200 Mbps. Following a previous problem (now resolved) with contention in my area, I check my speed regularly and recent average speeds are as follows:
Pre-increase, dates 20/7 - 28/7 average = 134 Mbps
Pre-increase, dates 29/7 - 2/8, on holiday
Pre-increase, dates 3/8 - 11/8 average = 136 Mbps
Post-increase, dates 11/8 - 18/8 average = 137 Mbps
Post-increase, dates 18/8 - 25/8 average = 139 Mbps
so my speed appears to have increased slightly but not by the step change I would have expected.
I have a TP-Link Wifi adapter attached to my PC that allegedly can handle speeds up to 300 Mbps so I have not made any changes to any settings.
Is there some change I need to make to get the full benefit of the increased speed or is there some other problem?
  • 2.96K
  • 378
  • 939
Message 2 of 19
Re: David, you're flying at your new speed ... or not?
You could check that your super hub has picked up the correct 200Mbs config. If you go to http://192.168.100.1/ to get the super hub GUI. Don't login but instead click on the Router Status button in the top right of the screen. On the next screen click on Operation Configuration then look for Primary Downstream Service Flow. Under that heading the value for Max Traffic Rate should be 220000000 bps if your hub is correctly configured for 200Mbs.
Wireless is easily disrupted by a number of external factors, so a wired test is the best way to get a true picture of what speed your line is able to achieve. Wireless adapter makers always quote theoretical speeds, so your wireless adapter is unlikely to get anywhere near 300Mbps in the real world.
______________________
Scott
  • 35
jellyroll
Message 3 of 19
Thanks for your reply. My super hub appears to be configured correctly.
I appreciate what you say about wired tests and that my adapter may never achieve 300 Mbps but, to counter that, even before the alleged speed increase, I have occasionally recorded speeds between 145 and 150 Mbps so my set up should be able to deal with speeds up to that level.
  • 9.88K
  • 323
  • 854
Hero
Message 4 of 19
I appreciate what you say about wired tests and that my adapter may never achieve 300 Mbps...
Sounds like you have done the simple tests and checks then...so what speed do you get in modem mode with a PC to the modem mode port?
  • 2.96K
  • 378
  • 939
Message 5 of 19
The key word being "occasionally" because wireless is rarely stable enough to give consistent results.
Regardless, VM don't guarantee wireless speeds so without a wired test to see what speed is being delivered to the hub it is almost impossible to diagnose where the speed bottleneck is.
Scott
  • 5.37K
  • 273
  • 1.18K
Message 6 of 19
You may not of changed anything with your setup but other factors outside of your control may of changed.
Generally speaking as wireless becomes more congested as more people get into it, the speeds will drop.
If you want speeds you are just going to have to wire up, or get AC network cards in your tech and a good AC 3rd party router.
Convienience comes at a cost.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
  • 35
jellyroll
Message 7 of 19
Thanks for the replies. I appreciate that connecting my PC to the superhub with an Ethernet cable would be helpful but I'm not sure if the Ethernet adapter in my PC is fast enough. If I go into Device Manager/Network Adaptors, I see "NVIDIA nForce 10/100 Mbps Ethernet" listed. Am I correct in assuming this would not deal with speeds above 100 Mbps?
  • 2.96K
  • 378
  • 939
Message 8 of 19
You are correct.  You need a gigabit (10/100/1000) Ethernet adapter to get speeds above 100Mbps.
Scott
  • 35
jellyroll
Message 9 of 19
I've been waiting patiently in the hope that someone from Virgin Media might reply. In the meantime, speeds have actually got worse rather than better. Since Fault F003238436 was resolved in June (see my Post "152 Mbps or not") download speeds were solid at around 135 Mbps. In the last couple of weeks they have been extremely variable.
  • 5.37K
  • 273
  • 1.18K
Message 10 of 19
Seems like you've somehow slipped through the net. Will flag it for you.
@ModTeam
