  • 19
RichG82
Constant Dropouts
Keep having constant dropouts and registration failues in router mode and modem mode on hub 3 (vivd 300), posting my power levels and my logs, if you could have a check everything is ok it would be apreciated.
 logs
2016-12-01 06:28:19.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-01 06:29:00.0082000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-01 06:30:03.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-01 06:31:42.0082000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-01 06:32:01.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-01 06:32:01.0084020300MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-01 06:32:15.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-01 06:32:32.0082000700Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-01 06:32:33.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-01 06:33:04.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-01 06:33:04.0084020300MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-01 06:33:18.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-01 06:33:36.0082000700Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-01 06:33:36.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-01 06:35:13.0082000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-01 06:35:32.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-01 06:35:32.0084020300MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-01 06:36:02.0082000700Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-01 06:36:03.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-01 06:39:26.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
upstream
Channel ID Frequency(Hz) Mode Power
7 24400000 ATDMA 48 64 qam 6400000 5120
6 31000000 ATDMA 48 64 qam 6400000 5120
downstream
Channel Frequency(Hz) Power
(dBmV) SNR
(dB) Modulation Channel ID
1 299000000 8 38.6 256 qam 13
2 323000000 7.6 38.6 256 qam 16
3 315000000 8 38.9 256 qam 15
4 307000000 8 38.9 256 qam 14
5 291000000 7.8 38.6 256 qam 12
6 283000000 7.9 38.9 256 qam 11
7 275000000 7.9 38.9 256 qam 10
8 267000000 8 38.9 256 qam 9
9 259000000 8 38.6 256 qam 8
10 251000000 8.3 38.9 256 qam 7
11 243000000 8.4 38.9 256 qam 6
12 235000000 8.5 38.9 256 qam 5
13 227000000 8.5 38.9 256 qam 4
14 219000000 9 38.9 256 qam 3
15 211000000 9 38.6 256 qam 2
16 203000000 9 40.3 256 qam 1
  • 19
RichG82
Re: Constant Dropouts
any response?
upstream power now at 54
  • 19
RichG82
a whole week with no response from staff, what a joke!
  • 3.88K
  • 120
  • 203
Forum Team (Retired) Adam_L
Hi RichG82,
Thanks for the post! I am sorry to hear about your issues with your constant dropouts. I apologise for any inconvenience caused.
I have tested things from here and everything looks great! No errors or time outs and all of your power levels are within the preferred ranges.
Are you still having these issues? If so, please respond to me here with a recent copy of your Hubs logs for me to compare with the data we have here.
Also, what does the Hubs light sequence indicate?
Take care,
Adam.
