fkp
Message 1 of 9
Connection reliability issue with VIVID 200 Optical Fibre
Hello,
I've been having reliability issues with the Internet for over a week now. It shows its ugly face by dropping packets, cutting out on VoIP, freezing screens in Video chats and interrupting server connections and connections to remote services.
I've spoken to a Technical Support on Sunday who did some testes and told me everything was fine.
I've attached a few screen shots, one of them being the Network log which shows a constant "Lost MDD Timeout" (pictures 1).
Network LogNetwork Log
The next one of the Network Status (picture 2).
Network StatusNetwork Status
I hope somebody will be able to shed some light into this.
Cheers in advance!
Karl
Helpful Answers
  • 3.01K
  • 383
  • 952
Message 2 of 9
Re: Connection reliability issue with VIVID 200 Optical Fibre
Hi Karl
the network log is useless as a bug in the firmware has caused it to fill the log with the same duplicate message, note the same time stamp for all of them.
The downstream doesn't look good as you only appear to have 7 channels locked on and you should have at least 8.
The person you spoke to on Sunday has fobbed you off as there is clearly something not right with your connection.  You could try calling again or wait for the forum team to get this thread and see what they suggest.  I think you will need a technician to visit and investigate the cause of the missing downstream channel.
______________________
Scott
All Replies
  • 3.01K
  • 383
  • 952
Message 2 of 9
Hi Karl
Scott
fkp
Message 3 of 9
Hello SCA1972,
Thank you for your reply. The log did look different a few days ago where the time between the logs and that error was between 30-50 seconds. I'll clear the log restart the hub and see what happens as well as give them another call.
Cheers!
Update:
New Network log screen shot.
Network log 2Network log 2
fkp
Message 4 of 9
Updated Network status. The missing channel 0 is active again.
  • 3.01K
  • 383
  • 952
Message 5 of 9
Glad to hear that the missing channel is back, but it is not a healthy channel with SNR too low and far too many post RS errors.
Now that you have a log which is correctly displaying errors it is also showing an unhealthy connection with too many timeout errors in quick succession.
Scott
  • 10.62K
  • 311
  • 654
Message 6 of 9
Hey there fkp,
Thanks for getting in touch and apologies for the problems you're having with your connection. I can see that Scott has identified the issues which would require an engineer visit. I'll drop you a PM (purple envelope, top right) to arrange this.
Talk soon,
Take care.
Heather_J
fkp
Message 7 of 9
Hi Heather_J and Scott,
Thank you for your replies and the pointers.
After calling technical support this morning again and the automated system telling me there's nothing wrong and to restart the router. I unplugged it for about 5-10 Minutes and after starting it up again and a quick look at the Downstream Channels as well as a ping test, the connection is reliable again with no lost packets.
I can't remember how often I restarted or unplugged the router in the last 9 days to hope it would sort itself out, but I'm glad it did now! I didn't have any drop outs in the last few hours! Smiley Happy
Cheerio,
Karl Smiley Happy
  • 3.01K
  • 383
  • 952
Message 8 of 9
Hi Karl
the hub stats look much healthier now, so hopefully the issue is resolved, but keep an eye on it and post back if anything changes.
Scott
  • 10.62K
  • 311
  • 654
Message 9 of 9
Hey fkp,
That's good to see!
Thanks for keeping us in the loop and thanks again to Scott for prompt and efficient diagnostics as always!
Hope you both have a great weekend,
Take care.
Heather_J
