  • 8
LBayford
Connection problems (Area 24)
I have been having problems with my Internet connection for the past few weeks, and over the last 3 days or so it has gotten almost unusable. Constant time outs loading Webpages and slow speeds even when it is working.
Everytime I check my service status it says everything should be fine, I run the test and it doesn't get to 100% before changing to the 'we're trying to sort it out for you' page. But nothing changes.
I understand that faults occur and accept the odd downtime, but this is getting ridiculous now. I would appreciate some help.
Many thanks.
  • 7.36K
  • 314
  • 523
Re: Connection problems (Area 24)
Hi LBayford,
Welcome to the Community!
Really sorry to hear you're having trouble with your connection.
I've located your account and I can see an issue with your signal levels that is likely causing the issues you've described. I've sent you a private message (purple envelope at the top right of your screen) so I can arrange for a technician to take a look.
Speak soon Smiley Very Happy
Josh
