  • 160
wilksbrighton
Connection issues
Hello VM,
For the last 2 weeks i have been experiencing connection issues with my broadband where i had to reset the superhub. today after resetting the superhub i noticed the power levels were all higher than they were a 1 month ago. the download power lvls was edging towards +14dBmv.
Also, my phone line wouldnt work when i tried to call 150. after resetting SH it started to work again.
can someone check my stuff please??
Wilksbrighton
Helpful Answers
  • 8.32K
  • 361
  • 588
Re: Connection issues
Hi ,
Welcome to the Community!
Really sorry to hear you're having trouble with your connection.
I've located your account and I can see an issue with the network in your area affecting speeds at peak times - Ref.(F004868778). Our technicians are working to get this resolved and have set a review date of 17th May 2017.
I've also picked up issue with both your Upstream and Downstream Power levels that will need to be adjusted by a technician. I've sent you a private message (purple envelope at the top right of your screen) so I can arrange an appointment.
Speak soon Smiley Very Happy
Josh
  • 10.94K
  • 238
  • 2.02K
Hi Martin - just remoted into your SH2AC and D/S is sitting somewhat chilly between -7 and -9dBmv  with U/S a tad warm at 50/52dBmv on 16QAM which also raises some questions about the current efficacy of your HDU? Post RS are concerning albeit probably because you haven't rebooted for a day or 3?
Let's hope Networks are optimising your cable segment with replacement taps/amps and you can eventually get decent signal at your end of the cable lobe your hung out on, without a separate HDU? In meantime when you eventually arrange a tech visit then remember if Networks are doing what I suspect  they're doing then your visit could get cancelled at 11th hour! Smiley Sad
Curiously your Feb2017 SK data was better than mine and still apparently averaging 211.39/12.09mbps for your V200 so far for March?  Go figure?
(Just as well I didn't install your Synology NAS before your mum and I departed for our Selsey Beach Hut otherwise your connection issues would have pointed an accusing finger in my direction! Smiley Wink )
Good luck with tech visit/segment update and talk more when we're back home in about 10days or ring us on my mob or CVan mob?
Regards Tony
"Life is a Binary Inspired Turing Computed Hologram"(don't PM or @Mention me - in case ignoring you offends)
All Replies
  • 8.32K
  • 361
  • 588
Hi ,
Josh
  • 160
wilksbrighton
HI Josh,
Its seems i havent received the private message. Could you resend please?
Thanks.
  • 10.94K
  • 238
  • 2.02K
Regards Tony
