  • 25
d4vow
Connection Constantly Dropping - Again
Back again, after running solidly for a couple of months after my last post here > http://community.virginmedia.com/t5/Networking-and-wireless/3-Months-of-Disconnections-150-No-Help-a...
We are back to the constant disconnects...
I have called The "Technical Support" team who advised
"pop it in modem mode, there are no faults our end"
Current Issue
The connection works fine for a few hours, then becomes sluggish.  VOIP drops, Netflix will stop / become very slow.  The tick on the modem does't flash - I assume because the connection is up and down constantly.
Pings to Google Show:
Modem Status
I am so infuriated with the constant issues. The lack of 150 Technical Knowledge.  It seems very poor to tell your customer with slow/unusable internet to "post on our forums"
My apologies if this message is not in the lightest of spirits, but I am just sick and tired of having to go through all of this again.
Kind Regards
David
thejammie9
Re: Connection Constantly Dropping - Again
Did you try turning it off and on again ?
If so move to business it might work better and you will actually have internet
  • 3.88K
  • 120
  • 203
Forum Team (Retired) Adam_L
Hi d4vow,
Thanks for the post! I am sorry to hear about your connection constantly dropping, I apologise for any inconvenience.
I have tested things from here and I can see that there's a lot of time outs inside the Hubs logs and an engineer will need to attend in order to resolve this for you.
I will send you a PM (Purple envelope at the top) detailing what's required to proceed with making the booking. Please respond to me there and I'll get this all sorted for you.
Take care,
Adam.
