  • 126
  • 30
Spitfire16
Up to speed
Message 1 of 16
Check Connection please (Superusers?)
Hi Folks,
just wondering if someone could check my connection for issues such as time-outs etc?
Many thanks in advanced
DownStream
Channel Frequency(Hz) Power
(dBmV) SNR
(dB) Modulation Channel ID
12987500001.540.3256 qam17
23227500001.540.9256 qam20
33147500001.740.3256 qam19
43067500001.540.3256 qam18
52907500001.238.9256 qam16
62827500001.440.3256 qam15
72747500001.240.3256 qam14
82667500001.440.3256 qam13
92587500001.240.9256 qam12
102507500001.240.3256 qam11
112427500001.240.3256 qam10
122347500001.240.3256 qam9
132267500001.240.3256 qam8
142187500001.540.9256 qam7
152107500001.540.9256 qam6
162027500001.740.3256 qam5
17194750000240.3256 qam4
18186750000240.3256 qam3
191787500001.740.3256 qam2
201707500001.740.3256 qam1
Upstream
Upstream bonded channels Channel ID Frequency(Hz) Mode Power
546200000ATDMA43.364 qam64000005120
825800000ATDMA43.364 qam64000005120
732600000ATDMA43.364 qam64000005120
639400000ATDMA43.364 qam64000005120
And Time Error Number Event Description
2017-05-29 11:06:27.00 68010400 DHCP REBIND WARNING - Field invalid in response;CM-MAC=;CMTS-MAC=a;CM-QOS=1.1;CM-VER=3.0;
2017-05-29 11:06:27.00 68010600 DHCP Renew - lease parameters tftp file-V3c1310bb03cca99.cm modified;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2017-05-30 04:44:14.00 82000200 No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2017-06-01 12:26:14.00 68010100 DHCP RENEW sent - No response for IPv4;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
2017-06-02 08:26:13.00 68010400 DHCP REBIND WARNING - Field invalid in response;CM-MAC=;CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
2017-06-02 08:26:13.00 68010600 DHCP Renew - lease parameters tftp file-V3c1310bb03cca99.cm modified;CM-MAC=c;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2017-06-06 21:31:22.00 68010100 DHCP RENEW sent - No response for IPv4;CM-MAC=;CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
2017-06-07 17:23:07.00 82000200 No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
2017-06-07 19:50:09.00 68010100 DHCP RENEW sent - No response for IPv4;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
2017-06-08 01:19:42.00 82000200 No Ranging Response received - T3 time-out;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
2017-06-08 01:24:50.00 68010100 DHCP RENEW sent - No response for IPv4;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2017-06-08 03:16:27.00 68010400 DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-06-08 03:16:27.00 68010600 DHCP Renew - lease parameters tftp file-V3c1310bb03cca99.cm modified;CM-MAC=;CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
2017-06-09 03:37:51.00 82000200 No Ranging Response received - T3 time-out;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
2017-06-11 09:04:26.00 68010100 DHCP RENEW sent - No response for IPv4;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2017-06-12 03:18:22.00 82000200 No Ranging Response received - T3 time-out;CM-MAC=CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2017-06-12 03:38:24.00 68010100 DHCP RENEW sent - No response for IPv4;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
2017-06-12 06:17:37.00 68010400 DHCP REBIND WARNING - Field invalid in response;CM-MAC=;CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
2017-06-12 06:17:37.00 68010600 DHCP Renew - lease parameters tftp file-V3c1310bb03cca99.cm modified;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2017-06-15 01:41:08.00 82000200 No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
  • 460
  • 21
  • 102
Andy1975
Fibre optic
Message 2 of 16
Re: Check Connection please (Superusers?)
Your power levels and SNR look spot on.. You are getting fairly regular T3 timeouts though which is not good, VM team will look closer for you in a week or so.
  • 126
  • 30
Spitfire16
Up to speed
Message 3 of 16
Thank's Andy,
I will wait for VM staff members to check my connection/CMTS Smiley Happy
  • 16.52K
  • 1.38K
  • 3.38K
Message 4 of 16
hiya @Spitfire16 yeah looks not bad, you can read about the power levels and the specs they should be within could look at -> http://community.virginmedia.com/t5/QuickStart-set-up-and/POWER-LEVELS-and-SNR-A-TECHNICAL-PRIMER-up...
regards superusers you requested
  • 126
  • 30
Spitfire16
Up to speed
Message 5 of 16
Thank you Paul,
I will wait to hear from VM about my T3's which someone who has flagged above , Hopefully everything is ok at my end and also at the CMTS i'm connected too
  • 10.72K
  • 314
  • 658
Message 6 of 16
Hey Spitfire16,
Thanks for getting in touch Smiley Happy
Sorry for your recent connection issues. I can see you've called in since your last post and since your last reboot (1 day ago) you've only had 2 T3 time-outs.
Has this settled down for you now?
Speak soon,
Take care.
Heather_J
  • 126
  • 30
Spitfire16
Up to speed
Message 7 of 16
Hi Heather,
Many Thanks for your prompt reply,
I actually called to report latency issue's which is being reported on my BQM Graph,  i have attached a few of my graphs below for you to look at , please note my internet connection is idle from Midnight - 9AM , little use during the day and more usage over the course of the evening , i'm unsure why my connection is always spiking , from my knowledge the connection shouldn't be spiking all the time?
I have checked all my BQM graphs from May 1st 2017 to the current day and they all report ping spikes all day and night , a selection from the past few days is below
27/06
https://www.thinkbroadband.com/broadband/monitoring/quality/share/2ec21466baf99d09ee9ddf4bc38988a009...
26/06 - at 11AM approx is when your colleague rebooted the modem remotely , your colleague said she would forward this to level 2 / network for further investigation as to why the connection is always spiking does my account notes reflect this ? , Immediately after the reboot the connection starts to spike
https://www.thinkbroadband.com/broadband/monitoring/quality/share/5b910b4365de056c85dbe4b52b1c3769c2...
25/06
https://www.thinkbroadband.com/broadband/monitoring/quality/share/fcf6ad0f00e94fbb9460f702403639ce43...
Looking forward to your response
  • 126
  • 30
Spitfire16
Up to speed
Message 8 of 16
  • 9.42K
  • 317
  • 1.02K
Message 9 of 16
Hello Spitfire16
Thanks for the updates we have taken a thorough look at your connection. The hub and line parameters are nicely in spec. The area traffic does have the occasional spike in the evening and that may give the odd bit of lag however overall it remains quite low. The area upstreams are performing well ie noise and error free.
I am sorry but the BQM performance may be related to this issue Re: Hub 3 / Compal CH7465-LG (TG2492LG) and CGNV4 Latency Cause
Thank you
Nicola
Virgin Media Forum Team
  • 126
  • 30
Spitfire16
Up to speed
Message 10 of 16
Hi Nicola,
Many thanks for your response to my thread , it is much appreciated .
I have done 2 pings tests to both bbc.co.uk and to multiplay.co.uk (A Game Server Provider - UK Network)
https://prnt.sc/frxo5n
The left ping test is to the bbc.co.uk and the right one is to multiplay.co.uk
Ive also done a trace route to both bbc.co.uk and multiplay.co.uk using winmtr (delay is set to 1.0 Sec) ,
 from the bbc.co.uk trace route I'm getting packet loss at  ( nrth-bb-1c-ae1-0.network.virginmedia.net and tele-ic-4-ae0-0.network.virginmedia.net )
Trace route BBC.co.uk - http://prntscr.com/frxrxa
Trace route to multiplay.co.uk - http://prntscr.com/frxt5k
Taking the above into account , is the problem down to the Hub 3.0 issues which you have talked about above?
When is the new firmware expected ?
Adam
