  • 5
pcpilot3
Message 1 of 11
Can get 200Mbps in router mode, nut NOT in modem mode?
147Mbps upgraded to vivid200 recently, with new hub3.
setup with my existing Netgear Nighthawk X6 and i cant get 200M speed, only 147 as before. If i connect direct to new hub in router mode, i can get over 200Mbps.
Am I missing some config paramater on my router?
Anyone with similar problem?  Thanks all.
Helpful Answers
  • 5.37K
  • 273
  • 1.18K
Message 5 of 11
Re: Can get 200Mbps in router mode, nut NOT in modem mode?
Does just sound like settings of the nighthawk or Quality of Service settings limiting it.
Nighthawk should outperform VM one easily.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
All Replies
  • 9.48K
  • 651
  • 1.81K
Message 2 of 11
has to be a setting on router - you could try a reset or check the lan cable between the hub3 and your router - that needs to be cat5e minimum
____________________
Tony
  • 5
pcpilot3
Message 3 of 11
Cable is Cat6a.  Smiley Sad
Base spec of the router doesnt say what might be the restriction. [frustrated]
  • 9.48K
  • 651
  • 1.81K
Message 4 of 11
can you save the config for the router if you have personalised settings - if so do that and then press the reset button to take it to factory defaults - see what that does
as to the lan cable - change it anyway if you have a spare just to say its not that
Tony
  • 5.37K
  • 273
  • 1.18K
Message 5 of 11
  • 46
supershaun
Message 6 of 11
I also have the same router as you my superhub is in modem mode and i constantly gt 200+ meg wat settings on router are you using?
Check out my Ookla Speedtest result. What's your speed? http://www.speedtest.net/my-result/a/2318977973
  • 5
pcpilot3
Message 7 of 11
Firstly - really appreciate everyone's help - thanks. OK, so I get the same as I've been getting for months with my superhub1. 147Mpbs http://www.speedtest.net/my-result/5763283442 I'll check the settings on the X6 when I get some time tomorrow am but I cant see anything unusual. I've rebooted everything, but not put the X6 back to factory defaults yet. I'm running some wireless devices off the X6 and have wired connections to a Vonage hub (1 phone) and a Polycom desk phone and another netgear router acting as an AP in the loft and this desktop PC which is my primary (Win10, 16Gb ram, i7, loads of SSD disk) Thanks again all. pcp
  • 5
pcpilot3
Message 8 of 11
OK - Who mentioned QoS??!  Smiley Happy
Went to the "Advanced - Setup - QoS Setup" page on the router config and reran the speedtest button and got to 194Mbps, then click "Apply".
Now when I run the speedtest in Chrome window I can get >185. Smiley Happy  Happy Bunny.
Will check again in the morning to see if i can get both numbers > 200. (Now done it again and got >200  http://www.speedtest.net/my-result/5763746565 )
I guess the QoS was limiting my throughput on Chrome (or actually, overall)
Netgear Nighthawk X6 configNetgear Nighthawk X6 config
  • 5.37K
  • 273
  • 1.18K
Message 9 of 11
If you have no reason for the QoS you may as well disable it all together
  • 5
pcpilot3
Message 10 of 11
i use it to put the voice (Vonage and Polycom  - personal and business) at Highest priorities and daughter 2's video streaming NOT at highest priority! Smiley Happy
Is it worth doing that with 200Mbps ?
